Intel® ARC™ Graphics
ARC on WSL
Remlin379
This is just a question
Apparently ARC doesn't support virtualization at all
I can't pass it to WSL no matter what i do, it can only see a virtual microsoft GPU
But I know for a fact that the WSL worked with ARC, both in normal WSL and in docker
The internet has many videos and tutorials that also use it
Did Intel just drop the support and delete it from bios or something?
DeancR_Intel
Hi Remlin379,
Thank you for posting in the Community!
Apologies for the delay on my response. Yes, you are correct that ARC doesn't supports virtualization. Here's the link for your reference: Can Intel® Arc™ Drivers Be Installed on a Virtual Machine?
I just want to clarify what as well is the WSL you have mentioned.
Dean R.
Remlin379
Then how do you explain that it DID work before?
DeancR_Intel
Hi Remlin379,
Apologies for the delay on my response. I want to know more details about the issue you encountered.
Can you describe the issue more to us?
What is the system specification of the system that worked?
Dean R.
DeancR_Intel
Hi Remlin379,
I'm following up to find out if you experience any issues. I'm not able to get any response from you regarding the needed information.
Dean R.
DeancR_Intel
Hi Remlin379,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Dean R.
