Intel® ARC™ Graphics
3039 Discussions
Arc A750 short silence issue while seeking Youtube videos with DisplayPort
Leav
My monitor is connected to 1st DisplayPort output of A750. When I was watching Youtube video (using Firefox 116.0.3 64bit) and seeking, I noticed that there was a short audio silence (1~3 secs) after the video starts to play.  For example:
https://www.youtube.com/watch?v=leIK1aUOF-Q
I can reproduce this issue by pressing "5" key to jump to 50% of video.  Every time I pressed "5", I can see the video jumps, starts to play, but no music for about 3 secs.
I also tried:
- Connect my monitor via HDMI
- Watch Youtube video using Chrome via DisplayPort
Interestingly there is no such issue.  The music just goes well.
Here is my configuration:
- OS: Windows 10 22H2 19045.3324
- CPU: AMD R5-3600
- MB: Gigabyte A520M
- Video: Intel Arc A750, driver 31.0.101.4644, PAR enabled
- Monitor: Philips 288E2, 4K@60
Jean_Intel
Hello Leav,
Thank you for posting on the Intel️® communities. We would be more than glad to help you.
To better assist you, we would like to check the following information:
  • When did the issue start?
  • Is the audio coming from the monitor or any other audio device (headphones or speakers)?
  • Are you able to test using a different audio device?
  • Is the issue only present on YouTube? Does it also occur on other video websites (Twitch, Netflix)?
  • We want to gather more information about your system, so please create a system report using the following tools:
  • • Intel System Support Utility (Intel SSU)
    • Open the application and click "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View."
    • To save your scan, click "Next"; and then "Save."
  • Intel® Graphics Command Center:
    • Open the Intel Graphics Command Center
    • Navigate to the Support tab
    • Select System Diagnostic
    • Click Generate Report
    • Select Save and name the output file.
Jean O.
Leav
Both my A750 & monitor are newly bought
Monitor's built-in speaker
This issue also occurred if I plug a headphone into Audio-Out behind the monitor
Audio-Out behind motherboard -> Headphone => No such issue
Netflix + Firefox => Bad
Netflix + Chrome => Bad
Also occurred when dragging Win10 system volume control.  Sometimes I heard the chime sound and sometimes not.
See attached file for SSU report
Jean_Intel
Hello Leav,
Thanks for the information provided.
Based on your system report, we noticed that your graphics driver is 31.0.101.4644. There is a new driver version, 31.0.101.4669, and we recommend you install the new driver version. To discard the possibility that the issue is being caused by a previous driver file, try running the Display Driver Uninstaller. Check How to Use the Display Driver Uninstaller (DDU) to Uninstall an Intel® Graphics Driver for instructions. The DDU tool will eliminate all drivers and leftover files from previous driver versions.
Jean O.
Leav
Hi Jean,
Updated to 31.0.101.4669.  The issue still exists.
BTW I read the release notes and no DisplayPort audio updates are mentioned.
Jean_Intel
Hello Leav,
We understand that the issue remain after a driver update. We wanted to let you know that even though there is no information about audio updates being mentioned, it is always recommended to keep your system up to date, to have the latest implementations and fixes available. Nevertheless, we will continue researching this matter interanally and will post back as soon as we have further details.
Jean O.
Jean_Intel
Hello Leav,
Thank you for your patience. We would like to let you know that after looking into this matter, the solution for this issue is included with the Window 11 23H2 update, released on 10/31/2023. Based on this, we recommend you update your Operating System to this version and install the latest Intel Graphics Driver 31.0.101.4900.
Jean O.
Jean_Intel
Hello Leav,
Since we have not heard back from you, we will proceed to close this thread. Note that the solution for this issue is included with the Window 11 23H2 , and you should update your Operating System, we also recommend install the latest Intel Graphics Driver.
If you need additional details, you should open a new thread, as this one will no longer be monitored.
Jean O.
Leav
Hi Jean,
So it seems like an OS issue.
I tested the new driver on Win10 22H2.  This audio issue still exists.  Unfortunately I have no plan to upgrade to Win11, so I can't confirm if this issue was fixed.  Hope Intel can push MS to patch Win10 also.
