Intel® ARC™ Graphics
3300 Discussions
Arc Control monitoring metrics bug
Suzie1818
Since driver 4255, there has been a new bug that the "Fan Speed" item in the Arc Control monitoring panel, either the main UI or the in-game overlay, will disappear automatically when it drops to zero RPM and then reappear when the fans start spinning (for non-zero value). It seems like someone in your driver team deliberately made this change and considered it as a creative idea, which is not and is just totally stupid.
Hugo_Intel
Hello Suzie1818
Thank you for posting on the Intel® ARC™ Graphics Communities. We are sorry that you are experiencing this issue with the fan speed monitoring function and appreciate that you report the issue to us.
We would like to reproduce this issue and want to confirm with you whether the problem automatically happens when the fans' RPM reaches 0 or if you have specific steps that trigger this issue, if so, please share them with us.
Hugo O.
Suzie1818
The problem automatically happens when the fans' RPM reaches 0.
Hugo_Intel
Hello Suzie1818
Allow me to check this with our team. I will post back once I have an update for you.
Hugo O.
Hugo_Intel
Hello Suzie1818
We are still checking this issue. We would like to ask you, if possible, to provide a screenshot from the ARC Control UI as well as the overlay showing this issue, so we can compare the way that the Intel® Arc™ Control Software looks from your side once this issue happens.
Hugo O.
Suzie1818
@Hugo_Intel
I have recorded two video clips for you to see the difference.
Hugo_Intel
Hello Suzie1818
Thank you for sharing these videos with us. I will give you an update once I have more information. Thank you for the feedback.
Hugo O.
Hugo_Intel
Hello Suzie1818
We have confirmed and replicated this issue in our test lab. We also have documented and passed your feedback to the corresponding team so they can take a look at this issue. We appreciate your feedback and that you take the time to report his issue to us.
Hugo O.
Hugo_Intel
Hello Suzie1818
Since there are no further questions, we will close this thread. Do not hesitate in opening a new topic if you need further assistance.
Hugo O.
