Intel® ARC™ Graphics
3294 Discussions
Arc Control panel permanently disabled my ALT + O
chidaruma
So I got my A770, and everything is fine, except for one small but infuriating detail. The Arc Control Panel has its hotkeys as Alt + O and Alt + I by default, and it doesn't seem like I'm able to change them. In my language Alt + O is ó letter, but Arc hotkeys seems to take priority over my keyboard, as I'm unable to write ó any more after installing Arc Control. Despite uninstalling it, I'm still not able to return Alt + O shortcut to default, which means I'm not able to write in my native language! Any ideas how I can fix that?
Who thought that making such an unchangeable shortcut would be a good idea?
Jean_Intel
Hello chidaruma,
We have received your notification request that you would like to close this thread, so we are continuing to closing the thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Jean O.
Blade1981
the issue is not solved yet. I also want to use some shortcuts for windows options and the unchangeable shortcuts from intel arc are preventing me, using Alt + ?? (in my case Alt + h - which means a lot of more clicks and time for what I do).
So please make it changeable, or at least to make it possible to disable shortcuts at intel arc.
Thanks and best regards.
