Intel® ARC™ Graphics
3353 Discussions
Arc controller not responding
Prajjwal_Mishra
I Have installed arc 770 in my PC.
But when I trying to open arc controller software it open sometimes but not responding it stucks on and also when i press Alt+O then it open but do not show any info everything is blank.
I read so many article and do everything like reinstalling, clean installing, turn off resizable bar, installing clean beta version, etc but nothing happened
Its same all time.
This problem is start when i once turn on resizable bar.
PLEASE HELP!!!!
but gpu is working fine.
IsaacQ_Intel
Hello @Prajjwal_Mishra
Follow these steps to generate an Intel® Graphics Driver report for the Intel® Graphics Control Panel or the Intel® Graphics Command Center. Report for Intel® Graphics Drivers.
SSU
1.     Please download and scan your system using our tool, Intel® System Support Utility so we can help check your system info first. Once finished downloading, open the tool, click on scan 'Everything', click next, then save the system information to a .txt file. Please provide the .txt file.
 Also, we would like to know, if you tried the steps provided on this article:
Intel® Arc™ Control Interface Not Responding
Isaac Q.
IsaacQ_Intel
SSU
Isaac Q.
Prajjwal_Mishra
Intel® Graphics Command Center -> it is generating only a blank file.
as shown in screenshot it stuck immediately after opening and no details showing of graphics uses.
i tried again a clean installation but nothing happens.
IsaacQ_Intel
We are glad to know you found a solution, thank you for taking the time to share this fix, and hopefully, it may help other community members experiencing similar behavior. Since the thread is now solved, we will proceed to close it. Please keep in mind that this thread will no longer be monitored by Intel. Thank you for your understanding.
Isaac Q.
