Intel® ARC™ Graphics
3295 Discussions
Asrock Arc A770 8gb fan speed max RPM problem
lee1988
As mention above, my GPU fan speed wont get stop or slow down even below 40'c,i need to restart my pc every single time in order to stop it , tis thing happened once i launch any game, pls advice
-done DDU twice with latest intel driver 31.0.101.5333
-asrock b365m phantom gaming 4 with latest bios update
VonM_Intel
Hi, lee1988.
Thank you for posting in our Intel communities.
Have you tried to manually change the fan speed through Intel Arc Control? This feature will allow setting a customized fan curve. If yes, how which setting are you using?
Also, did the fan speed max RPM work before, and when you encountered this issue? Sorry for so many questions, but sometimes it’s the most random thing that's causing the issue.
Looking forward to your response. Have a nice day ahead!
Von M.
lee1988
hi, if i change fan speed thru  arc control center ,no matter by fan curve or by percentage, it will  run on full speed  and wont get slow down or stop even at idle.
00pol00
VonM_Intel
Hi, lee1988.
I hope you are doing fine.
Kindly let us know if you still need assistance.
Von M.
VonM_Intel
Hi, lee1988.
When you attempt to modify the fan speed using the fan curve or percentage adjustments, it doesn't seem to affect the fan's operation, which persists at maximum speed. This might indicate an issue with the software not properly applying the settings. Let me gather the following details in order for us to further understand the situation.
  • Could you confirm if you've updated your driver to version 31.0.101.5379?
  • Could you provide the specific RPM reading when the fan is at full speed?
  • Have you observed any excessive noise from the fan when it's running at this high speed?
Moreover, I would like to go a step further and confirm details such as processor, graphics models, drivers, and system errors. The Intel SSU tool can gather such details about your system configuration that may help me root cause of this issue.
Von M.
VonM_Intel
Hi, lee1988.
I trust you're doing well.
I have not heard back from you, we will close this inquiry now. If you need further help, please submit a new question as this thread will no longer be monitored.
Von M.
00pol00
Same problem here, max rpm all time asrock Arc a770 phantom gaming 16gb
Danvos
Same problems here; Tried about everything that is purposed in this topic, but no vail.
Only solution is to restart the PC.
Today I tried a simulair card ARC a770 16 GB and everything is back to normal. So definitly the Graphics card is defective and will RMA it for repair, it is still under warranty
