Intel® ARC™ Graphics
Comunicados
3401 Discussões
B580显卡在游戏时切屏或弹出桌面,显卡占用率异常的问题
刘坤然
Principiante
8.332 Visualizações
在我游玩的主要游戏,三角洲,黑神话悟空和绝区零中,按照2k高画质的设置,显卡占用率基本都在60%到80%之间,所有游戏在游玩过程中不存在其他问题。但是在弹出系统桌面,或切换其他软件到前台时,显卡占用率会直接来到100%,导致游戏闪退(三角洲)或者蓝屏(黑神话悟空)。我根据网络上的一般解决办法,比如重装系统,更换驱动等方式,均无法解决该问题。以下为部分游戏中显卡正常和异常的对比图。
下图为三角洲游戏画面,分别为普通游戏界面,切换其他软件和弹出桌面。可以很明显看到切屏后显卡占用率上升异常。此时频繁切换会导致游戏卡死。而在3A游戏黑神话悟空中,出现的情况和三角洲一样。但黑神话这边,我在截取屏幕图片时,也会频繁出现蓝屏情况,截取游戏画面难度大,因此仅放上一张蓝屏图。
考虑到仅在部分游戏中会有这样的情况出现,经过初步判断,我认为是显卡驱动问题,当然不能完全排除显卡硬件的问题。以上是所有的问题内容,还请工程师或懂行的人帮忙解答,谢谢。
三角洲游戏界面三角洲游戏界面其他软件在前台其他软件在前台弹出桌面弹出桌面黑神话悟空蓝屏黑神话悟空蓝屏
29 Respostas
刘坤然
Principiante
929 Visualizações
1.The blue screen issue also occurs when I use the Alt+Tab key to switch between the game and the desktop or other programs. Similar to popping out to the desktop, it usually appears after two or three switches.
2.In fact, the power supply manufacturer only includes two PCIe 4.0 specification dual 8-pin power cables as standard. After reseating the power cables or adjusting their connection positions on the power supply unit, the blue screen problem still occurs.
3.The blue screen issue persists with the latest version 6913 driver.
4.I reinstalled Windows 11 two weeks ago, but as indicated in my recent feedback, reinstalling the system did not resolve this issue.
刘坤然
Principiante
932 Visualizações
  1. The blue screen issue also occurs when I use the Alt+Tab key to switch between the game and the desktop or other programs. Similar to popping out to the desktop, it usually appears after two or three switches.
  2. In fact, the power supply manufacturer only includes two PCIe 4.0 specification dual 8-pin power cables as standard. After reseating the power cables or adjusting their connection positions on the power supply unit, the blue screen problem still occurs.
  3. The blue screen issue persists with the latest version 6913 driver.
  4. I reinstalled Windows 11 two weeks ago, but as indicated in my recent feedback, reinstalling the system did not resolve this issue.
As for replacing other power supply cables or testing on a different computer platform, given my limited time, I will not pursue these options at the moment. I have been using the B580 graphics card for two months now. During this period, I have reviewed numerous reviews of this graphics card and inquired about the usage experiences of other users who purchased it. I tentatively suspect that the blue screen issue might be related to the specific silicon characteristics (or "individual card quality") of my particular graphics card unit. However, based on current observations, the card exhibits no other problems during daily use, light gaming, or when running professional software. When playing Black Myth: Wukong, as long as I avoid popping out to the desktop or switching applications, the gameplay remains smooth, as previously mentioned. I am unsure if similar issues would arise with other AAA games, but at least for now, I am relatively satisfied with the performance of this graphics card. Therefore, whether this blue screen issue is completely resolved is no longer a top priority for me. At the same time, I appreciate your team's continuous analysis and support regarding this problem over this period. Finally, I sincerely wish Intel continued success in developing its graphics card products.
刘坤然
Principiante
932 Visualizações
It seems that because of my mistakes, I posted a lot of duplicate content, and I don't know how to delete the redundant comments, so I'm sorry
刘坤然
Principiante
932 Visualizações
ArchieD_Intel
Moderador
859 Visualizações
Hello 刘坤然
Thank you for the feedback, I will check this again and will get back to you as soon as I have a solution. Thank you for your patience.
Best regards
Archie D.
ArchieD_Intel
Moderador
818 Visualizações
Hello 刘坤然
My research indicates that the error "0x119_d000_UNKNOWN_dxgmms2!VidSchiCommitFlipQueueLogUpdate" from the dump suggests several troubleshooting steps: updating graphics drivers, checking Windows updates, scanning for malware, checking for software conflicts, performing a clean boot, conducting a system restore, and reinstalling DirectX. Since you have already performed a clean OS reinstall, these issues should have been addressed.
I recommend removing and reseating the Arc GPU in your system. Please ensure the PCIe slot is clean, and the GPU's golden fingers are free of debris, then test the system again.
If the issue persists, I need to determine whether the problem lies with the system/PSU or the GPU itself. If you have another GPU available for testing or can try the Arc GPU in a completely different system, this will help further isolate the issue.
If you have any concerns, please let me know. Thank you.
Best regards
Archie D.
ArchieD_Intel
Moderador
804 Visualizações
Hello 刘坤然
Did you have a chance to review the previous post? Please feel free to reach out if you have any questions. Thank you.
Best regards
Archie D.
ArchieD_Intel
Moderador
766 Visualizações
Hello 刘坤然
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Best regards
Archie D.
fishi
Principiante
669 Visualizações
和你一样的问题,
把显示器设置重置就解决了
Responder
