Intel® ARC™ Graphics
3288 Discussions
B580 Problems in Call of Duty Black Ops 6
Radbod
i ve the following Problems :
1: Frame Drops in Open Environments in Black Ops 6 , Frames Drop from 140 down to <60 fps (For example Rewind and Extraction)
2: Frame droping down to <70fps when i watch Youtube Videos on the Second Monitor and CPU has 100% utilization
  • Testet with Opera and Edge
  • After killing the process it goes back up >100fps
3: After the newest Patch in BO6 ALL Weapon camos turned Red
SSU attached
Mike_Intel
Hello Radbod,
  1. When did you purchase your Arc B580?
  2. Are you using an Intel brand Arc B580?
  3. Was it working fine before?
  4. What is your game launcher?
  5. What is the specifications of your power supply?
  6. What are the troubleshooting steps that you tried so far?
Michael L.
Radbod
SSU and Jpegs Attached and here the answers needed :
30.12.2024
ASROCK Intel ARC B580 Steel Legend
With the first Drivers i had no Framedrops
XBox
Seasonic B12 BC 850 Watt 80 PLUS Bronze Certified
DDU Clean install , Disabling iGPU, Running only CoD and disabling any Services regarding browsers
Ive eSport Graphic settings (All shadows and lightning and surface disabled, everything else to medium but textures to high) and XESS Balanced Mode
*UPDATE*
Ive Downgraded the driver to Version 32.0.101.6257 and used the internal BO6 Benchmark.
AVG FPS are 12% , Low FPS are 13,1% and 1% low FPS are 13% higher then with the 6559 Driver! Ingame FPS are insanely higher too (Sometimes 50% faster)
Mike_Intel
Hello Radbod,
Thank you for the update.
Let me gather additional details for documentation of the issue.
  1. Is there a chance that you can try this game on a different launcher like Steam?
  2. When using Xbox launcher, are you also having issues with other games?
Michael L.
Mike_Intel
Hello Radbod,
Michael L.
Mike_Intel
Hello Radbod,
I am sending another follow up on the information that I requested.
Michael L.
