Intel® ARC™ Graphics
3341 Discussions
Battlefield 1 problem with B580
Borillo
There's a lag when playing the Battlefield 1 under DirectX 12, but DirecX 11 has no this problem.
There is stuttering every few seconds, and the 1% Low - frame rate is very low.
Methods to Reproduce the Issue:Set Battlefield 1 graphics to Ultra,resolution 100%
The system is Windows 11 24H2.
My driver version: 32.0.101.6790
Memory :SK Hynix A-die 32GB
Motherboard :Gigabyte Z890M-Aorus-Elite-7
CPU:Ultra 7 265K.
Game Platform: Steam
Power Supply: Super Flower LEADEX III 850W
ArchieD_Intel
Hi Borillo,
Does the issue occur only during cutscenes? Or does it also happen during regular gameplay or menus?
When did the issue start? Was it after a specific driver update or game patch?
What are the troubleshooting steps that you tried so far other than changing into DX11?
Is the Resizable Bar enabled?
Have you used DDU to completely remove all residual drivers and installed a new one?
Have you tried adjusting the graphics settings?
Could you provide a screenshot of your in-game display and graphics settings?
Which gaming platform did you use to download the game?
I would also like to obtain 3 CapFrameX log to thoroughly analyze the FPS performance. Kindly ensure that the game would run for a minimum of 3 minutes each.
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility.
Archie D.
Borillo
Ok I will gather more information for you, thank you.
ArchieD_Intel
Hi Borillo,
I just wanted to follow up so that we can determine the best course of action to resolve this matter. Your feedback at your earliest convenience would be greatly appreciated. Thank you.
Archie D.
ArchieD_Intel
Hi Borillo,
Archie D.
