Intel® ARC™ Graphics
3285 Discussions
Bug ID 14019166699 - Have you not found a solution for Lumion for this error?
HashRD
I have the same error when I finish installing Lumion on my PC but no matter how many things I have done, nothing gives me a solution to correct the display.
Andres_Intel
Hello HashRD,
Thank you for posting on the Intel communities. I see you want to know if we have found a solution for the Lumion graphics corruption and flickering issue, I know this is very important for you, I will more than glad to help you.
At this time Intel is investigating this issue in collaboration with the application developer. We are working really hard with them to find a solution as soon as possible.
Let me know if you have further questions.
Andres P.
Andres_Intel
Hello HashRD,
Were you able to check the previous post? Remember that Intel is investigating this issue in collaboration with the application developer
Andres P.
Andres_Intel
Hello HashRD,
Seems you do not have further questions, so I will continue with the investigation, as soon I have a fix for this I will let you know.
Andres P.
Andres_Intel
Hello HashRD,
Thank you for your time.
We have been working really hard in the investigation, and I want to let you know that in Lumion 23 the flickering textures/graphics issue (not the menu corruption) should be fixed with driver 31.0.101.5081 and newer.
Please follow the steps below and let me know the results:
  1. Clean install the graphics drive with the Display Driver Uninstaller (DDU). For guidance, How to Use the Display Driver Uninstaller (DDU) to Uninstall an Intel® Graphics Driver.
  2. Install the graphics driver to version 31.0.101.5081.
Andres P.
Andres_Intel
Hello HashRD,
Did the graphics update to version 31.0.101.5081 fix the issue?
Andres P.
Andres_Intel
Hello HashRD,
Andres P.
