Intel® ARC™ Graphics
3310 Discussions
CS2 Perfomance with the Arc A750
Rifat46
I have a750 and ryzen 5 5600 and I am getting low fps. I was playing everything on low stretched 4:3 on the x960 res and the game jumps from 200 to 100 to 90 fps constantly no constant fps. I don't know if the problem is on arc drivers or in cs2. The fps in low-high is basically same. A750 should be outperforming rtx 3050, but it isn't.
Labels (2)
Madis
is the problem solved ? i have the same situation.
Earl_Intel
Hi Rifat46,
To better assist you and determine the most appropriate resolution, could you please provide the needed details listed below:
  • is the game working fine before?
  • when did you encounter the issue?
  • is your sam enabled?
  • what is your maximum refresh rate on your monitor?
  • What is the exact game settings on your CX2?
  • Are you also experiencing the same issue with different games?
  • What graphics driver version do you have?
  • Have you already tried to roll back your graphics driver version? if yes, what driver version have you rolled back to?
Earl E.
Earl_Intel
Hi Rifat46,
Earl E.
bobbycold_h
Hi all,
there can sometimes be issues with games using DX10 or lower due to the Alchemist cards only natively supporting DX11 & 12. I've had a similar issue with Splinter Cell: Conviction before, which using ForceD3D9on12 fixed - maybe you'd like to give that a try?
You just have to open the game folders (navigate to them or while in Steam right-click on the game, "Manage", "Browse local files") and drop the files from the ForceD3D9on12 .zip file to the folder where the game executable resides.
You can download that from here: https://github.com/narzoul/ForceD3D9On12/releases/download/v1.0.0/ForceD3D9On12-v1.0.0.zip These files just enforce using the ForceD3D9on12 compatibility layer which is already included with Windows 10 and 11.
Please try it out if you're able to and reply if problems persist.
Robert W. (bobbycold_h)
Xzorn
That didn't work, just tried it but no luck.
Xopio
It's a bottleneck with your cpu majorly, check your usage of both your cpu and gpu, cs2 you must be playing on low settings, try using a bit more high settings. In valorant it happens to me too, my mid graphics and low graphics fps are the same because I am running my a770 with a intel i5 10th gen cpu... At 1080p there isn't bottleneck but at 1440*900 4:3 res it is a bottleneck you can see for yourself through the bottleneck calculator for approx value. But a bottleneck calculator cant replicate cs2. Do tell me if the situation persists which most probably will.
RandyT_Intel
Hi Rifat46,
Since I have not received any response from you, I will proceed with closing this ticket. Please note that this case will no longer be monitored.
If you have any new questions or inquiries, kindly submit another ticket, and we will be happy to assist you.
For other community members @bobbycold_h @Madis , kindly create your own ticket for inquiries so that we can further assist you.
Randy T.
