Intel® ARC™ Graphics
CS2 crashes
Bandit8623
New Contributor III
cs2 crashes.  game just closes no error.  5333 driver.  same happens for valorant.  driver 5194 no crashes
1440p 
Bandit8623
New Contributor III
@RonaldM_Intel
Looks like i had unstable ram in my pc.  ran prime95 on ram test and got errors in 20min.  i since have rectified the ram.  my guess this was the crash reasons.  ill know more over the weekend as i have some val and cs matches this sunday.
thanks
Bandit8623
New Contributor III
adding another
Bandit8623
New Contributor III
another
RonaldM_Intel
Hi @Bandit8623
Sorry for answering until now... it has been a busy week.
Have you experienced any other crash on CS2 since then? The reason I'm asking is because I have been testing and benchmarking CS2 for a while now and haven't experienced any crash yet (not even on 101.5333). Is it crashing more often on any map or game mode?
By the way, I analyzed the dump files you submitted (thanks by the way!) and from the 3 dumps:
1. crash_cs2.exe_20240308221419_1.dmp -> failure occurred with 'engine2.dll' component.
FAILURE_BUCKET_ID: INVALID_POINTER_READ_c0000005_engine2.dll!Unknown
2. crash_cs2.exe_20240308211156_1.dmp -> failure occurred with 'rendersystemdx11.dll' component.
FAILURE_BUCKET_ID: NULL_POINTER_READ_c0000005_rendersystemdx11.dll!Unknown
3. crash_cs2.exe_20240308200045_1.dmp -> failure occurred with 'igd10umt64xe.dll' component.
FAILURE_BUCKET_ID: INVALID_POINTER_READ_c0000005_igd10umt64xe.DLL!Unknown
Out of the 3 only 1 crash is related to a driver component (igd10umt64xe.dll) so I'll look into it but it might have been due to an incorrect app call. The other 2 crashes are related to the application itself so there may be more happening there. Have you reinstalled the game?
Ronald M.
Bandit8623
New Contributor III
@RonaldM_Intel
thanks for looking into.  I will do some game reloading and pc stability tests in the next few days.  since valorant is crashing too its possible i have a hardware stability elsewhere.   ill update when i know more
thx
Bandit8623
New Contributor III
@RonaldM_Intel
CONFIRMED no crashing since fixing ram stability.
Bandit8623
New Contributor III
@RonaldM_Intel
thanks
