Intel® ARC™ Graphics
3289 Discussions
Call of Duty (MW3 and Warzone): Poor Performance on Intel Arc A770
bani1o7
Hey there,
I'm reaching out because I'm having some serious performance issues with my Intel Arc A770 while playing Call of Duty: Warzone Resurgence at 1440p.
Even with the lowest graphics settings at both 1080p and 1440p. At 1080p the frame rates are way below what I expected, making the game less enjoyable then on GPUs of the competition.
What’s really disappointing is that using Intel XeSS, especially in Ultra Quality mode at 1440p, only gives me a slight boost in performance but still performing worse than native 1080p. I was really hoping this tech would make a bigger difference.
I've already updated all the usual drivers and tried various in-game settings, but nothing seems to work. I would really appreciate your help in resolving this issue.
It would be super helpful if you could answer a few questions for me: Are there any known issues with the Intel Arc A770 and Warzone (Resurgence) that are currently being looked into?
Is there a timeline for new driver releases aimed specifically at improving Arc graphics cards for Warzone or Call of Duty (Resurgence)?
Thanks a lot for your time and support.
Bani
Rusle
I tried it and it boosted my fps up to 170-200fps and all was good, but i have ended up with a movement delay, tried reapply my backup, but the graphics wouldnt reset. So i think i need to try reinstall, but thanks for the tweak buddy, its probably just a minor detail to get the delay away, but coding isnt my strong side, so dont know where to begin tbf
bani1o7
Ah thats unfortunate. I looked further into the settings and found that FSR Frame Gen was activated somehow. This is probably what's causing the delay. When I disable Frame Gen, the performance returns to 60-90 FPS. If you prefer not to reinstall, simply turn off Frame Gen. Open the text file I mentioned earlier, press “CTRL + F” to locate the Interpolation Setting, and set it to “false.”
Rusle
It might be something different aswell, as I also had pixel distortion on my screen all over my screen, dont know if frame gen can cause that, the current screen im using is odessey g5 32 curved with (2560 x 1440)
165hz
