Intel® ARC™ Graphics
3327 Discussions
Chrome with Arc A750 screen noise
ArielDeil
I have Arc A750 with i9 CPU.
Every time i open chrome the whole screen displays colorful noise flickering.
The same happens when I moved the A750 to AMD PC.
Both PCs running win11.
It only goes away when I disable Hardware Acceleration in chrome settings.
This also happens with latest Photoshop version..
Attached an image..
RandyT_Intel
Hello ArielDeil,
The issue might be related to the GPU drivers. Ensuring that you have the latest drivers installed is crucial. Since the problem persists across different PCs (both Intel and AMD), it suggests that the issue is specific to the GPU rather than the CPU or other hardware components
Make sure you have the latest Intel Arc A750 drivers installed. You can download the latest drivers from the Intel website. Check if your motherboard has any BIOS updates available and ensure that your power supply unit (PSU) is sufficient for your GPU. Insufficient power can sometimes cause graphical issue
Randy T
RandyT_Intel
Hello ArielDeil,
I hope you had the opportunity to review the information I posted. At your earliest convenience, please let me know so we can determine the best course of action to resolve this matter efficiently.
Randy T.
RandyT_Intel
Hello ArielDeil,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Randy T.
