Intel® ARC™ Graphics
3469 Discussions
DOOM The Dark Ages, Arc A380, visual artifacts.
Mynameforum
The game DOOM The Dark Ages and also Indiana Jones and The Great Circle uses same game engine and has same problem with dark/black shadows.
Game test arc a380 6gb https://www.youtube.com/watch?v=bAR4QeT6xNg
Nvidia card are totally fine rtx 3050 6gb https://www.youtube.com/watch?v=gyjoWwbem2o
No glitches on Nvidia. Both cards dont use raytracing in those games, but Arc is making problems for unknown reason.
I fixed time ago black shadows in Indiana Jones on my Arc A380 by forcing raytraycing ON via exe patch, but DOOM uses denuvo and the patch is questionable to make for a year of more.
Here detailed video https://www.youtube.com/watch?v=GrKVI7SBnRM
Do something.
Also the problem can be related to highter vram usage on Arc GPU. Because black shadows also appeared on mobile rtx 3050 4gb people said.
Here my post https://community.intel.com/t5/Intel-ARC-Graphics/Intel-Arc-higher-VRAM-usage-than-competitors-texture-compression/m-p/1685686
ArchieD_Intel
Hi Mynameforum,
Thank you for reaching out to the Intel Community Forum. I've sent an email to your active email address. Please check both your Inbox and Spam folder for my email, and once received, kindly acknowledge it.
Archie D.
ArchieD_Intel
Hi Mynameforum,
To assist us in investigating the issue, please provide the following details:
  • Does the issue occur only during cutscenes? Or does it also happen during regular gameplay or menus?
  • When did the issue start? Was it after a specific driver update or game patch?
  • Have you used DDU to completely remove all residual drivers and installed a new one?
  • Which gaming platform did you use to download the game?
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility.
Archie D.
Mynameforum
1. It appears during regular gameplay and cutscenes, menus are fine.
2. The problem not related to game versions or driver version. The issue 100% persist in drivers from 101.6319, (101.6449 i personally tested Indiana Jones) to 6790 doom the dark ages release game version tested by other person on youtube.
3. Yes i use DDU to unistall and instalate new drivers.
4. I tested Indiana Jones steam version with all patches etc.
Everything else in opening post.
ArchieD_Intel
Hi Mynameforum,
Thank you for the update. The current driver installed to your system is the 32.0.101.6449, I would like to suggest installing first the 32.0.101.6793 (Latest) and test it to see if the issue will be resolved. Please also perform clean installation.
If you have any questions, please let me know. Thank you.
Archie D.
Mynameforum
Archie D. i updated the driver. That was old ssu report, but the problem still persist in driver 32.0.101.6793, previous driver unistalled using DDU.
See screenshot and video - https://drive.google.com/file/d/1j7UK5KMNW7avPNXblyxpdoSXm7vGzmsc/view
The game runs at 60-70 fps at 720p, but with visual artifacts. the driver 32.0.101.6793!
Just run the game Doom The Dark Ages on Arc A380 in the Intel lab and check for black shadows.
The only known way to fix this is to force the game use raytraced shadows via exe hack/patch.
ArchieD_Intel
Hi Mynameforum,
Thank you for the update. Have you tried clean installation with the latest driver? Please send us another copy of the SSU with the latest driver install for us to check your system configuration. I will be investigating this in my end.
Archie D.
Mynameforum
Yes i tried clean installation. SSU is a bit faking the data. My RAM voltage is 1.3 v for 3600 frequency and CPU is cecond generation pinnacle ridge zen+ variant. Rebar is ON! PCIe 3.0.
ArchieD_Intel
Hi Mynameforum,
Thank you for providing the requested information. I will now further investigate this and will get back to you once a resolution is available. Thank you for your patience and understanding.
Archie D.
ArchieD_Intel
Hi Mynameforum,
After conducting a thorough investigation, we have determined that the problem may be related to the Arc 380 graphics card's VRAM capacity. The card has 6GB of VRAM, which does not meet the game's minimum requirement of 8GB VRAM. This insufficient VRAM could be causing difficulties in properly rendering the images.
For more detailed information and insights, I recommend reaching out to the game developer directly. They may be able to provide additional guidance or solutions specific to the game. You can contact the game developer through the following link provided on the id Software websitehttps://www.zenimax.com/en/more
Additionally, upgrading your hardware to meet at least the minimum system requirements is advisable to ensure optimal performance and visual quality.
Thank you for your understanding, I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Archie D.
