Intel® ARC™ Graphics
3294 讨论
Dark boxes around buildings graphical glitch Far Cry 3 AND Far Cry 4 (both Ubisoft Connect)
whynoteatcats
初学者
8,036 次查看
Far Cry 3 and 4 have a strange dark box glitch around buildings.
In Far Cry 3 these appear in Direct X 11, but not Direct X 9.
You can't change Direct X in Far Cry 4, it's also Direct X 11.
No amount of changing graphical settings resolves the problem.
I am using the current driver (31.0.101.4369).
I am running Windows 11, using an A750 and have included an SSU report and a video of the issue.
Based on my experience, this should be very easy to replicate in the lab. Considering that these games are in the same engine, it is likely that Far Cry 3 Blood Dragon and Far Cry Primal have similar issues but I haven't checked those.
I am not the most technical minded so hope this helps!
Seriously, I have tried every combination of graphical settings possible in both and the issues always remains.
Thanks!
标签 (2)
0 项奖励
5 回复数
Jean_Intel
员工
7,999 次查看
Hello @whynoteatcats
Thank you for posting on the Intel️® communities. I am sorry to hear that you are experiencing issues with the Intel® Arc™ A750 Graphics
  • Which game distribution service you used to install the game? (Blizzard, Epic, Origin, Steam, Xbox, Ubisoft connect, Microsoft Store)
  • Is Resizable BAR enabled in your BIOS?
Regarding this issue, we would like to recommend running the Display Driver Uninstaller. Check How to Use the Display Driver Uninstaller (DDU) to Uninstall an Intel® Graphics Driver for instructions. Once you run the tool, you should install the latest driver from Intel 31.0.101.4502. The DDU tool will eliminate all drivers and leftover files from previous driver versions.
Jean O.
0 项奖励
whynoteatcats
初学者
7,987 次查看
Hi Jean!
Both Far Cry 3 and 4 are on Ubisoft Connect and resizeable bar is enabled on my bios.
I downloaded Display Driver Uninstaller, uninstalled the old driver and installed 31.0.101.4502
The issue with the dark boxes is still presenting.
0 项奖励
Jean_Intel
员工
7,941 次查看
Hello whynoteatcats,
We would like to inform you that we are currently working on this problem. Unfortunately, we can't commit to any time for this, but rest assured that we are working on it.
We will report your environment internally. Once we have further information, we will post back.
Jean O.
0 项奖励
Jean_Intel
员工
7,726 次查看
Thanks for waiting for a response. After reviewing this issue, we want to let you know that a new driver version, 31.0.101.4644, is available on our website. This version contains a fix for the dark shadow issues in Far Cry 4. Please try this driver update and let us know the outcome.
Jean O.
0 项奖励
Jean_Intel
员工
7,664 次查看
We hope you are doing fine.
As we mentioned before, the new driver version includes a fix for the dark shadow issues in Far Cry 4. Since we have not heard from you, we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
0 项奖励
回复
