Intel® ARC™ Graphics
3294 Discussions
Detorit:become human can't be opened correctly
panjinhan
Sometimes the game can start for the first time when i install the gpu drive,but then cannot start until i reinstall the drive.In the newest drive i even cannot start the game.
By the way,the game cannot go correctly
panjinhan
If you have any suggests you can email me at <email removed> thank for your help
ArchieD_Intel
Hi panjinhan,
  • When did the issue start? Was it after a specific driver update or game patch?
  • What are the troubleshooting steps that you tried so far?
  • Have you used DDU to completely remove all residual drivers and installed a new one?
  • Have you tried adjusting the graphics settings?
  • Which gaming platform did you use to download the game?
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility.
Archie D.
panjinhan
first,the problem started when i first use the intel arc b580
second,i tried many different drivers include whql and not whql.I tried to uninstall the gpu driver by ddu but it doesn't pays off
third,i use steam to download the game
my computer's cpu is i5 13490f
band is b760m
I'll be helpful if you give me suggestions
Pan
ArchieD_Intel
Hi panjinhan,
Thank you for the update. Can you please provide a sample video showing the issue.
Additionally, please provide the Intel® System Support Utility to better understand your system configuration.
Archie D.
panjinhan
thanks,here are the pic when i start the game.
ssu information:
# SSU Scan Information
Scan Info:
Version:"4.1.0.0"
Date:"06/13/2025"
Time:"00:00:21.9954906"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"MAXSUN"
BIOS Mode:"UEFI"
BIOS Version/Date:"American Megatrends International, LLC. B2.3G , 12/24/2024 12:00 上午"
CD or DVD:"Not Available"
Embedded Controller Version:"255.255"
Platform Role:"Desktop"
Processor:"13th Gen Intel(R) Core(TM) i5-13490F , GenuineIntel"
Secure Boot State:"Off"
SMBIOS Version:"3.6"
Sound Card:"Realtek High Definition Audio"
System Manufacturer:"MAXSUN"
System Model:"MS-Challenger B760M"
System SKU:"Default string"
System Type:"x64-based PC"
- "Graphics"
Intel ® Graphics Driver Version:"32.0.101.6881"
- "Intel(R) Arc(TM) B580 Graphics"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"2.00 GB"
Bits Per Pixel:"32"
- "Caption":"Intel(R) Arc(TM) B580 Graphics"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Arc+B580+Graphics"
CoInstallers:"oem1.inf,BMG_IAG_E20B_FWU_wNext,Internal,Intel(R) Arc(TM) B580 Graphics Family"
Color Table Entries:"4294967296"
Dedicated Video Memory:"12116 MB"
Driver:"igdkmdnd64.sys"
Driver Date:"06/04/2025 08:00 上午"
Driver Path:"C:\Windows\system32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_f81d3bfa2d4c4488\igdkmdnd64.sys"
Driver Provider:"Intel Corporation"
INF:"oem1.inf"
INF Section:"BMG_IAG_E20B_FWU_wNext"
Install Date:"Not Available"
Installed Drivers:"C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_f81d3bfa2d4c4488\igd9trinity64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_f81d3bfa2d4c4488\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_f81d3bfa2d4c4488\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_f81d3bfa2d4c4488\igd12umd64.dll"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"Intel Corporation"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_E20B&SUBSYS_20141EF7&REV_00\6&21C23F12&0&00080008"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"60 Hz"
Refresh Rate - Maximum:"144 Hz"
Refresh Rate - Minimum:"23 Hz"
Resolution:"3840 X 2160"
Scan Mode:"Noninterlaced"
Service Name:"igfxnd"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"16303 MB"
Video Processor:"Intel(R) Arc(TM) B580 Graphics Family"
- "Memory"
Physical Memory (Available):"25.84 GB"
Physical Memory (Installed):"32 GB"
Physical Memory (Total):"31.84 GB"
- "BANK 0"
Capacity:"16 GB"
Channel:"Controller0-ChannelA-DIMM0"
Configured Clock Speed:"3200 MT/s"
Configured Voltage:"1200 millivolts"
Data Width:"64 bits"
Form Factor:"DIMM"
Interleave Position:"First position"
Manufacturer:"Asgard"
Maximum Voltage:"Not Available"
Memory Type:"Unknown"
Minimum Voltage:"Not Available"
Part Number:"VAM4UX32C22AG-SFREBI"
Serial Number:"000008A4"
Status:"Not Available"
Type:"Synchronous"
- "BANK 0"
Capacity:"16 GB"
Channel:"Controller1-ChannelA-DIMM0"
Form Factor:"DIMM"
Interleave Position:"Second position"
Serial Number:"00000494"
Type:"Synchronous"
- "Motherboard"
BIOS:"B2.3G, ALASKA - 1072009"
Caption:"主板"
Chipset:"Not Available"
Date:"12/24/2024 12:00 上午"
Model:"Not Available"
Part Number:"Not Available"
PNP Device ID:"Not Available"
Product:"MS-Challenger B760M"
Serial Number:"Default string"
Status:"OK"
Version:"Not Available"
- "Networking"
Intel ® Network Connections Install Options:"Not Available"
Intel ® Network Connections Version:"Not Available"
Intel ® PROSet/Wireless Software Version:"Not Available"
- "Bluetooth Device (Personal Area Network)"
Caption:"Bluetooth Device (Personal Area Network)"
CoInstallers:"Not Available"
Default IP Gateway:"Not Available"
DHCP Enabled:"Yes"
DHCP Lease Expires:"Not Available"
DHCP Lease Obtained:"Not Available"
DHCP Server:"Not Available"
Driver:"bthpan.sys"
Driver Date:"06/21/2006 12:00 上午"
Driver Path:"C:\Windows\system32\drivers\bthpan.sys"
Driver Provider:"Microsoft"
Driver Version:"10.0.26100.4061"
Index:"0013"
INF:"bthpan.inf"
INF Section:"BthPan.Install"
Installed:"Yes"
IP Address:"Not Available"
IP Subnet:"Not Available"
Last Reset:"06/13/2025 02:41 下午"
MAC Address:"F4:4E:FC:0F:DC:22"
Manufacturer:"Microsoft"
Net Connection ID:"蓝牙网络连接"
NetCfgInstanceId:"{41931057-05FD-4352-8EEE-7FB7C8224C8B}"
PNP Device ID:"BTH\MS_BTHPAN\6&10FB0BA2&0&2"
Port:"Not Available"
Power Management (Low Power):"Not Available"
Power Management (Wake On LAN):"Not Available"
Power Management (Wake on Magic Packet):"Not Available"
Power Management Supported:"No"
Product Type:"Bluetooth Device (Personal Area Network)"
Service Name:"BthPan"
Status:"Enabled"
Type:"以太网 802.3"
- "Service Bindings"
链路层拓扑发现响应程序:
链路层拓扑发现映射器 I/O 驱动程序:
Internet 协议版本 4 (TCP/IPv4):
Internet 协议版本 6 (TCP/IPv6):
Microsoft 网络的文件和打印机共享:
Microsoft 网络客户端:
Microsoft LLDP 协议驱动程序:
- "Realtek PCIe GbE Family Controller"
Caption:"Realtek PCIe GbE Family Controller"
DHCP Enabled:"Yes"
DHCP Lease Expires:"06/13/2025 02:41 下午"
DHCP Lease Obtained:"06/13/2025 02:41 下午"
DHCP Server:"255.255.255.255"
Driver:"rt640x64.sys"
Driver Date:"05/24/2024 12:00 上午"
Driver Path:"C:\Windows\system32\drivers\rt640x64.sys"
Driver Provider:"Realtek"
Driver Version:"10.72.522.2024"
Index:"0000"
INF:"oem17.inf"
INF Section:"RTL8168M.ndi.NT"
Installed:"Yes"
IP Address:"169.254.254.149;fe80::6253:332c:bae8:6e13"
IP Subnet:"255.255.0.0;64"
MAC Address:"48:F3:17:19:34:A7"
Manufacturer:"Realtek"
Net Connection ID:"以太网"
NetCfgInstanceId:"{49A9B04F-B3FC-412F-81F4-37E92701A5E8}"
PNP Device ID:"PCI\VEN_10EC&DEV_8168&SUBSYS_012310EC&REV_2B\01000000684CE00000"
Power Management (Low Power):"Active: Yes, Enable: Yes"
Power Management (Wake On LAN):"Active: Yes, Enable: Yes"
Power Management (Wake on Magic Packet):"Active: Yes, EnableWakeOnMagicPacketOnly: No"
Product Type:"Realtek PCIe GbE Family Controller"
Service Name:"rt640x64"
Status:"Enabled"
Type:"以太网 802.3"
链路层拓扑发现响应程序:
Microsoft 网络客户端:
QoS 数据包计划程序:
- "Settings"
*FlowControl:流控制:"Rx & Tx 开启 (3)"
*InterruptModeration:中断调整:"开启 (1)"
*IPChecksumOffloadIPv4:IPv4 硬件校验和:"Rx & Tx 开启 (3)"
*JumboPacket:巨型帧:"关闭 (1514)"
*LsoV2IPv4:大量传送减负 v2 (IPv4):"开启 (1)"
*LsoV2IPv6:大量传送减负 v2 (IPv6):"开启 (1)"
*ModernStandbyWoLMagicPacket:Wake on magic packet when system is in the S0ix power state:"关闭 (0)"
*NumRssQueues:接收端调整最大伫列:"4个伫列 (4)"
*PMARPOffload:ARP 减负:"开启 (1)"
*PMNSOffload:NS 减负:"开启 (1)"
*PriorityVLANTag:优先级和VLAN:"优先级和VLAN 开启 (3)"
*ReceiveBuffers:接收缓冲区:"1024 (1024)"
*RSS:接收端调整:"开启 (1)"
*SpeedDuplex:连接速度和双工模式:"自动侦测 (0)"
*TCPChecksumOffloadIPv4:TCP 硬件校验和 (IPv4):"Rx & Tx 开启 (3)"
*TCPChecksumOffloadIPv6:TCP 硬件校验和 (IPv6):"Rx & Tx 开启 (3)"
*TransmitBuffers:传送缓冲区:"128 (128)"
*UDPChecksumOffloadIPv4:UDP 硬件校验和 (IPv4):"Rx & Tx 开启 (3)"
*UDPChecksumOffloadIPv6:UDP 硬件校验和 (IPv6):"Rx & Tx 开启 (3)"
*WakeOnMagicPacket:魔术封包唤醒:"开启 (1)"
*WakeOnPattern:样式比对唤醒:"开启 (1)"
AutoDisableGigabit:自动关闭 Gigabit:"关闭 (0)"
PowerSavingMode:Power Saving Mode:"关闭 (0)"
RegVlanid:VLAN ID:"0 (0)"
S5WakeOnLan:关机 网络唤醒:"开启 (1)"
WolShutdownLinkSpeed:网络唤醒和关机连接速度:"10 Mbps 优先 (0)"
- "Operating System"
.Net Framework Version:"2.0,3.0,3.5,4.0,4.8"
Boot Device:"\Device\HarddiskVolume1"
Internet Browser:"Internet Explorer,11.1882, Microsoft Edge,137.0"
Locale:"中国"
OS Manufacturer:"Microsoft Corporation"
OS Name:"Microsoft Windows 11 专业版"
Other OS Description:"Not Available"
Page File:"D:\pagefile.sys"
Page File Space:"9.50 GB"
Physical Memory (Available):"25.76 GB"
System Directory:"C:\Windows\system32"
Version:"10.0.26100 Build 26100.4202"
Virtual Memory (Available):"34.36 GB"
Virtual Memory (Total):"41.34 GB"
Windows Directory:"C:\Windows"
- "Installed Updates"
KB2151757:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [2025/6/6]"
KB2151757:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [2025/6/2]"
KB2467173:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [2025/6/2]"
KB2467173:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [2025/6/6]"
KB2468871:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Extended [Not Available]"
KB5054979:"Update [6/2/2025]"
KB5058499:"Update [6/2/2025]"
KB5059502:"Update [6/2/2025]"
KB982573:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [2025/6/6]"
KB982573:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [2025/6/2]"
Microsoft ASP.NET Core 8.0.14 - Shared Framework (x86):".NET [2025/6/2]"
SP1:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [Not Available]"
SP1:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [Not Available]"
- "Processor"
- "13th Gen Intel(R) Core(TM) i5-13490F"
Architecture:"x64"
ATPO:"Not Available"
Caption:"Intel64 Family 6 Model 191 Stepping 2"
- "Chipset Name":"13th Gen Intel(R) Core(TM) i5-13490F"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=13th+Gen++Core+i5+13490F"
CPU Speed:"2.50 GHz"
Current Voltage:"1.8 volts"
Driver:"Not Available"
Driver Date:"04/21/2009 12:00 上午"
Driver Path:"C:\Windows\system32\drivers\intelppm.sys"
Driver Version:"10.0.26100.4202"
Ext. Family:"Not Available"
FPO:"Not Available"
INF:"cpu.inf"
INF Section:"IntelPPM_Inst.NT"
Level 1 Cache:"10 x 288 KB"
Level 2 Cache:"10 x 9728 KB"
Level 3 Cache:"24 MB"
Load:"0%"
Manufacturer:"GenuineIntel"
Model:"191"
Name:"13th Gen Intel(R) Core(TM) i5-13490F"
Number of Cores:"10"
Number of Cores Enabled:"10"
Number of Logical Processors:"16"
Part Number:"To Be Filled By O.E.M."
Processor ID:"BFEBFBFF000B06F2"
Revision:"Not Available"
Serial Number:"To Be Filled By O.E.M."
Service Name:"intelppm"
Status:"OK"
Stepping:"2"
- "Storage"
- "aigo U330 USB Device"
Capablities:"Random Access, Supports Writing, Supports Removable Media"
Caption:"aigo U330 USB Device"
Cylinder - Total:"7648"
Description:"磁盘驱动器"
Error Code:"Device is working properly"
Firmware Revision:"PMAP"
Heads - Total:"255"
Index:"2"
INF:"disk.inf"
Interface Type:"USB"
Manufacturer:"(标准磁盘驱动器)"
Model:"aigo U330 USB Device"
Partitions:"2"
Physical Sector Size:"512"
PNP Device ID:"USBSTOR\DISK&VEN_&PROD_AIGO_U330&REV_PMAP\90001AA1C06FB354&0"
Policies:"Read Retention Priority=EqualPriority, Write Retention Priority=EqualPriority, Scalar Prefetch=Not Available, Block Prefetch=Not Available"
Sectors - Per Track:"63"
Sectors - Total:"122865120"
Serial Number:"9B03050410A0"
Size – Available:"48.50 GB"
Status:"OK"
Tracks - Per Cylinder:"255"
Tracks - Total:"1950240"
- "E:"
Availability:"Not Available"
Caption:"E:"
Compression Method:"Not Compressed"
Description:"可移动磁盘"
File System:"exFAT"
Serial Number:"BE1188F7"
Volume Dirty:"No"
- "Fanxiang S101 480GB"
Capablities:"Random Access, Supports Writing, SMART Notification"
Caption:"Fanxiang S101 480GB"
Cylinder - Total:"58369"
Description:"磁盘驱动器"
Firmware Revision:"V0913A0"
Heads - Total:"255"
Index:"0"
INF:"disk.inf"
Interface Type:"IDE"
Model:"Fanxiang S101 480GB"
Partitions:"2"
PNP Device ID:"SCSI\DISK&VEN_&PROD_FANXIANG_S101_48\4&34DF4417&0&070000"
Sectors - Total:"937697985"
Serial Number:"AA000000000000001015"
Size – Available:"43.31 GB"
SMART Attributes:"Self-Test: 10 minutes, OK, Short Self-Test: 2 minutes, OK"
Status:"OK"
Tracks - Total:"14884095"
- "D:"
Caption:"D:"
Description:"本地固定磁盘"
File System:"NTFS"
Serial Number:"19E08723"
Volume Dirty:"No"
- "SMART"
0x01 Raw Read Error Rate:0:"50"
0x05 Reallocated Sector Count:0:"50"
0x09 Power-On Hours:319:"50"
0x0C Power Cycle Count:177:"50"
0xAF Power Loss Protection Failure:0:"50"
0xB0 Erase Fail Count (chip):0:"50"
0xB1 Wear Range Delta:0:"50"
0xB5 Program Fail Count Total:0:"50"
0xB6 Erase Fail Count:0:"50"
0xC0 Unsafe Shutdown Count:46:"50"
0xC2 Internal Device Temperature:26° C:"50"
0xC3 Hardware ECC Recovered:21854:"50"
0xC4 Reallocation Count:0:"50"
0xC5 Current Pending Errors Count:0:"50"
0xC6 Uncorrectable Sector Count:0:"50"
0xE8 Available Reserved Space:100:"50"
0xF1 Total LBAs Written:44941:"50"
0xF2 Total LBAs Read:40176:"50"
- "YMTC PC300-1TB-B"
Capablities:"Random Access, Supports Writing"
Caption:"YMTC PC300-1TB-B"
Cylinder - Total:"124519"
Description:"磁盘驱动器"
Firmware Revision:"YM0500C4"
Heads - Total:"255"
Index:"1"
INF:"disk.inf"
Interface Type:"SCSI"
Model:"YMTC PC300-1TB-B"
Partitions:"2"
Physical Sector Size:"4096"
PNP Device ID:"SCSI\DISK&VEN_NVME&PROD_YMTC_PC300-1TB-B\5&7979E8F&0&000000"
SCSI Bus:"0"
SCSI LUN:"0"
SCSI Port:"1"
Sectors - Total:"2000397735"
Serial Number:"0000_0000_0000_0000_A428_B726_5348_004A."
Size – Available:"788.82 GB"
Status:"OK"
Tracks - Total:"31752345"
- "C:"
Caption:"C:"
File System:"NTFS"
Serial Number:"BCABACD6"
Size – Available:"788.83 GB"
Volume Dirty:"No"
...#SSU#...
panjinhan
my computer is windows 24h2
cpu i5 13490f
ms challenger b760m
above 4g open realize bar open
i tried to uninstall the driver by ddu for some times
ssu information:
Scan Info:
Version:"4.1.0.0"
Date:"06/13/2025"
# Scanned Hardware
Computer:
BIOS Mode:"UEFI"
- "Graphics"
Bits Per Pixel:"32"
INF:"oem1.inf"
Monochrome:"No"
Status:"OK"
- "Memory"
- "BANK 0"
Capacity:"16 GB"
Form Factor:"DIMM"
Type:"Synchronous"
- "BANK 0"
Capacity:"16 GB"
Form Factor:"DIMM"
Type:"Synchronous"
- "Motherboard"
Caption:"主板"
Status:"OK"
- "Networking"
DHCP Enabled:"Yes"
Driver:"bthpan.sys"
Index:"0013"
INF:"bthpan.inf"
Installed:"Yes"
Status:"Enabled"
Type:"以太网 802.3"
链路层拓扑发现响应程序:
Microsoft 网络客户端:
DHCP Enabled:"Yes"
Index:"0000"
INF:"oem17.inf"
Installed:"Yes"
Status:"Enabled"
Type:"以太网 802.3"
链路层拓扑发现响应程序:
Microsoft 网络客户端:
QoS 数据包计划程序:
- "Settings"
*RSS:接收端调整:"开启 (1)"
Locale:"中国"
- "Processor"
Architecture:"x64"
FPO:"Not Available"
INF:"cpu.inf"
Load:"0%"
Model:"191"
Status:"OK"
Stepping:"2"
- "Storage"
Description:"磁盘驱动器"
Heads - Total:"255"
Index:"2"
INF:"disk.inf"
Partitions:"2"
Status:"OK"
- "E:"
Caption:"E:"
Description:"可移动磁盘"
File System:"exFAT"
Volume Dirty:"No"
Description:"磁盘驱动器"
Heads - Total:"255"
Index:"0"
INF:"disk.inf"
Partitions:"2"
Status:"OK"
- "D:"
Caption:"D:"
File System:"NTFS"
Volume Dirty:"No"
- "SMART"
Description:"磁盘驱动器"
Heads - Total:"255"
Index:"1"
INF:"disk.inf"
Partitions:"2"
SCSI Bus:"0"
SCSI LUN:"0"
SCSI Port:"1"
Status:"OK"
- "C:"
Caption:"C:"
File System:"NTFS"
Volume Dirty:"No"
...#SSU#...
panjinhan
cpu i5 13490f
ms challenger b760m
ssu information:
Scan Info:
Version:"4.1.0.0"
Date:"06/13/2025"
# Scanned Hardware
Computer:
BIOS Mode:"UEFI"
- "Graphics"
Bits Per Pixel:"32"
INF:"oem1.inf"
Monochrome:"No"
Status:"OK"
- "Memory"
- "BANK 0"
Capacity:"16 GB"
Form Factor:"DIMM"
Type:"Synchronous"
- "BANK 0"
Capacity:"16 GB"
Form Factor:"DIMM"
Type:"Synchronous"
- "Motherboard"
Caption:"主板"
Status:"OK"
- "Networking"
DHCP Enabled:"Yes"
Driver:"bthpan.sys"
Index:"0013"
INF:"bthpan.inf"
Installed:"Yes"
Status:"Enabled"
Type:"以太网 802.3"
链路层拓扑发现响应程序:
Microsoft 网络客户端:
DHCP Enabled:"Yes"
Index:"0000"
INF:"oem17.inf"
Installed:"Yes"
Status:"Enabled"
Type:"以太网 802.3"
链路层拓扑发现响应程序:
Microsoft 网络客户端:
QoS 数据包计划程序:
- "Settings"
*RSS:接收端调整:"开启 (1)"
Locale:"中国"
- "Processor"
Architecture:"x64"
FPO:"Not Available"
INF:"cpu.inf"
Load:"0%"
Model:"191"
Status:"OK"
Stepping:"2"
- "Storage"
Description:"磁盘驱动器"
Heads - Total:"255"
Index:"2"
INF:"disk.inf"
Partitions:"2"
Status:"OK"
- "E:"
Caption:"E:"
Description:"可移动磁盘"
File System:"exFAT"
Volume Dirty:"No"
Description:"磁盘驱动器"
Heads - Total:"255"
Index:"0"
INF:"disk.inf"
Partitions:"2"
Status:"OK"
- "D:"
Caption:"D:"
File System:"NTFS"
Volume Dirty:"No"
- "SMART"
Description:"磁盘驱动器"
Heads - Total:"255"
Index:"1"
INF:"disk.inf"
Partitions:"2"
SCSI Bus:"0"
SCSI LUN:"0"
SCSI Port:"1"
Status:"OK"
- "C:"
Caption:"C:"
File System:"NTFS"
Volume Dirty:"No"
panjinhan
cpu i5 13490f
ms challenger b760m
ssu information:
Scan Info:
Version:"4.1.0.0"
Date:"06/13/2025"
# Scanned Hardware
Computer:
BIOS Mode:"UEFI"
- "Graphics"
Bits Per Pixel:"32"
INF:"oem1.inf"
Monochrome:"No"
Status:"OK"
- "Memory"
- "BANK 0"
Capacity:"16 GB"
Form Factor:"DIMM"
Type:"Synchronous"
- "BANK 0"
Capacity:"16 GB"
Form Factor:"DIMM"
Type:"Synchronous"
- "Motherboard"
Caption:"主板"
Status:"OK"
- "Networking"
DHCP Enabled:"Yes"
Driver:"bthpan.sys"
Index:"0013"
INF:"bthpan.inf"
Installed:"Yes"
Status:"Enabled"
Type:"以太网 802.3"
链路层拓扑发现响应程序:
Microsoft 网络客户端:
DHCP Enabled:"Yes"
Index:"0000"
INF:"oem17.inf"
Installed:"Yes"
Status:"Enabled"
Type:"以太网 802.3"
链路层拓扑发现响应程序:
Microsoft 网络客户端:
QoS 数据包计划程序:
- "Settings"
*RSS:接收端调整:"开启 (1)"
Locale:"中国"
- "Processor"
Architecture:"x64"
FPO:"Not Available"
INF:"cpu.inf"
Load:"0%"
Model:"191"
Status:"OK"
Stepping:"2"
- "Storage"
Description:"磁盘驱动器"
Heads - Total:"255"
Index:"2"
INF:"disk.inf"
Partitions:"2"
Status:"OK"
- "E:"
Caption:"E:"
Description:"可移动磁盘"
File System:"exFAT"
Volume Dirty:"No"
Description:"磁盘驱动器"
Heads - Total:"255"
Index:"0"
INF:"disk.inf"
Partitions:"2"
Status:"OK"
- "D:"
Caption:"D:"
File System:"NTFS"
Volume Dirty:"No"
- "SMART"
Description:"磁盘驱动器"
Heads - Total:"255"
Index:"1"
INF:"disk.inf"
Partitions:"2"
SCSI Bus:"0"
SCSI LUN:"0"
SCSI Port:"1"
Status:"OK"
- "C:"
Caption:"C:"
File System:"NTFS"
Volume Dirty:"No"
ArchieD_Intel
Hi panjinhan,
  • Have you tried uninstalling or updating the game?
  • Have you tried clean installation of the latest graphics driver?
  • Can you please send me a picture of the message in English Language?
Archie D.
VonM_Intel
Hi panjinhan,
Von M.
ArchieD_Intel
Hi panjinhan,
Archie D.
