Every time I alt-tab in games like Ubisoft Rainbow Six Siege and Websites like YouTube, I always see screen problems like the one I attached to this forum. My Drivers are up to date, my bios is up to date and everything only started happening AFTER installing the Intel Arc A770. Is there anyway to fix it?
Hi Kenmist,
- When did the issue start? Was it after a specific update?
- What are the troubleshooting steps that you tried so far?
- Is the Resizable Bar enabled?
- Have you used DDU to completely remove all residual drivers and installed a new one?
- Can you please provide a video demonstrating the issue?
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility.
Archie D.
連結已複製
Hi Kenmist,
Archie D.
Hi Kenmist,
Archie D.
Hello Archie,
Very sorry about the late response I assumed it showed you I added it as a solution because what he said worked. ReBar was the issue and all I had to do was update my bios. Thank you very much
Kenmist.
