Intel® ARC™ Graphics
3357 Discussions
Dying Light 2 low FPS and GPU usage
Fedora
Whenever I use XeSS my FPS drops, especially by 1% and 0.1%. After a while, I feel like I'm playing at 20-25 FPS. If I turn off XeSS the GPU is always used at 100% but since I cannot play the game above 60 FPS without XeSS, I have to turn on XeSS. I'm playing around with ray tracing at 1080p highest settings and turning on XeSS in balanced mode. I did not encounter any problems such as graphics degradation. Specs: Intel ARC A770 Limited Edition, Ryzen 7500F with stock fan, Flare X5 DDR5 32gb RAM, Samsung EVO 970 2T, MSI MAG A750GL 750 Watt PSU.
Andres_Intel
Hello Fedora,
Thank you for posting on the Intel communities.I will be delighted to assist you. Since you are having low performance isue while playing Dying Light 2 with XeSS enabled in your Intel® Arc™ A770 Graphics, could you please respond to the following questions so that we can better identify the issue?
  • Is the graphics card an Intel Branded Card or is it of another brand? This is to check if the issue happens to a specific edition.
  • Take screenshots of the game settings, in case we need them to replicate the issue.
  • What tool do you use to check that the game runs at 20-25 FPS?
Andres P.
Andres_Intel
Hello Fedora,
Were you able to take screenshots of the game settings in case we need them later?
Andres P.
Andres_Intel
Hello Fedora,
Andres P.
