My specs are as follows:
System Description
- Core i5 14600K
- 32 GB DDR5-6000 CL32
- Intel Arc A770 Limited Edition
-Driver version: 32.0.101.7026
When Variable Rate Shading (VRS) is enabled in DOOM The Dark Ages, the whole screen will have ghosting and is unplayable. Video capture and SSU attached.
The problem fixes itself when VRS is turned off, and reappears when I turn it back on. I also have XeSS enabled at native rendering option.
Hi @holynoob299,
- Which digital distribution platform did you obtain the game that is experiencing graphics issues? (e.g., Steam, Epic Games Store, GOG, etc.)
- When did the issue first occur?
- Have you made any software or hardware changes to the system recently?
- Have you recently updated your Intel graphics driver, or did the issue begin after a specific update (Windows or driver)?
- Have you tried launching the game with different graphics settings (e.g., low/medium/high presets)?
- Does the ghosting appear immediately upon enabling VRS, or only after certain gameplay triggers?
- Does the ghosting occur with XeSS disabled or set to Balanced/Performance instead of Native?
- Kindly share some screenshots of your game settings so we can replicate and check the issue on our end using the same settings you use during gameplay.
Randy T.
Hi @holynoob299
The issue is known and has been reported here: https://github.com/IGCIT/Intel-GPU-Community-Issue-Tracker-IGCIT/issues/1194
Updates will be posted there.
Hi @holynoob299,
Just wanted to follow up on my previous response to your inquiry. Have you had a chance to review it?
I'd appreciate your feedback so I can determine the best next steps to assist you further.
@DorianApanel thank you for your help!
Thank you!
Randy T.
Hi @holynoob299,
Since I haven't heard from you, I will proceed with closing this case. Please note that it will no longer be monitored. However, you may submit a new ticket if you need further assistance in the future.
Randy T.
