Intel® ARC™ Graphics
3297 Discussions
Every time i change scaling mode option from display to gpu my intel app crash
Adam1221
Earl_Intel
Hi Adam1221,
I'm sorry to learn that you are experiencing issues with your system. To better assist you and determine the most appropriate resolution, could you please provide the needed details listed below:
  • May I know if your device is a desktop or laptop? if it's a laptop, what is the exact make and model of it?
  • Is scaling mode option working fine before?
  • Are there changes on the system before you encounter this issue?
Kindly run this on your system so that I can also gauge the following peripherals and the driver versions that you have:
Intel® System Support Utility for Windows*
Once finished downloading, open the tool, click on scan (leave the default items checked), click next, then save the system information to a .txt file. Please provide us the .txt file.
Earl E.
Earl_Intel
Hi Adam1221,
Earl E.
Adam1221
I am using a desktop computer. Scaling worked, but that was in December, a few updates ago. No significant changes have been made to the system.
Earl_Intel
Hi Adam1221,
Thank you for sharing this information with us, no worries, I will review the SSU logs that you provided and send an update on this thread as soon as possible.
Earl E.
Earl_Intel
Hi Adam1221,
Thank you for patiently waiting.
Can you confirm if the IGS is only crashing when changing the Scaling Mode or if it's also freezing?
If it's not much of a hassle, can you share the Application logs from the Event Viewer.
Earl E.
Earl_Intel
Hi Adam1221,
Just wondering if you had a chance to look over the questions I posted. In order to decide on the appropriate course of action to address the problem, kindly notify me as soon as possible.
Earl E.
Earl_Intel
Hi Adam1221,
Earl E.
