Intel® ARC™ Graphics
3435 Discussions
For the third time coming here to say performance problems when playing streaming on discord
AsterCrash
Good evening, I'm coming here again. I'm having performance issues when streaming while playing. I'll send the files as xcapframe and SSU.
Hardware acceleration disabled in Discord
Enabled efficient video decoding and Cisco System codec.
The game I tested and made the xcapframe for was RE8, but it happens with all my games, even Nikke, which is the lightest on my PC.
DeancR_Intel
Hi AsterCrash
Thank you for contacting Intel support again regarding the performance issues you're experiencing when streaming on Discord while gaming. I understand how frustrating this recurring issue must be, and I'm committed to helping you resolve it this time.
I can see that you've already taken some troubleshooting steps by disabling hardware acceleration in Discord and enabling efficient video decoding with Cisco System codec. You mentioned that this issue affects all your games, from RE8 to lighter games like Nikke.
To better assist you and provide the most effective solution, I need to gather some additional system information:
Could you please provide an Intel SSU (System Support Utility) report? You can download it from: https://www.intel.com/content/www/us/en/support/articles/000005567/processors.html
If you're not comfortable sharing the SSU report, please provide the following details:
  • CPU model and specifications
  • GPU model (Intel Arc, integrated graphics, or discrete GPU)
  • RAM amount and configuration
  • System model (if laptop) or motherboard model (if desktop)
  • Current graphics driver version
Troubleshooting History:
  1. Was this working properly before? If so, when did you first notice the streaming performance issues starting?
  2. Have you tried the latest Intel graphics driver? If so, please specify which version you tested. If not, I recommend updating to the latest version 32.0.101.7028 from: https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
  3. What specific performance symptoms are you experiencing? (frame drops, stuttering, encoding issues, etc.)
Given that this is your third time reporting this issue, I'd like to schedule a phone call for faster resolution.
Dean R.
AsterCrash
1. I've been having streaming issues since I installed it.
2. I'm using the latest version.
3. Frame drops and stuttering.
DeancR_Intel
Hi AsterCrash
Thank you for your continued patience and for providing the additional information regarding your streaming performance issues on Discord while gaming.
I understand that you've been experiencing this issue since installation, are using the latest driver version, and are encountering frame drops and stuttering during streaming. I also acknowledge that this affects all your games, from RE8 to lighter titles like Nikke, which indicates a systemic issue rather than game-specific problems.
Given that this is your third report of this issue and the persistent nature of the problem despite your troubleshooting efforts (disabling hardware acceleration in Discord, enabling efficient video decoding and Cisco System codec), I will be checking this internally to provide you with the most accurate solution. I will get back to you with detailed findings and recommendations once I have the necessary information from my internal review.
Dean R.
DeancR_Intel
Hi AsterCrash,
Before I proceed with my internal investigation, I'd like to try one more troubleshooting step that may resolve this persistent issue. Since you're experiencing system-wide streaming performance problems, I recommend performing a clean driver installation using DDU (Display Driver Uninstaller)
Have you tried using DDU to completely remove and reinstall your Intel graphics driver?
If not, please follow Intel's official DDU instructions:
Intel DDU Clean Installation Guide: Official Intel DDU Steps: https://www.intel.com/content/www/us/en/support/articles/000091878/graphics.html
Quick Overview:
  1. Download DDU: https://www.guru3d.com/files-details/display-driver-uninstaller-download.html
  2. Boot into Safe Mode: Restart your computer and boot into Safe Mode
  3. Run DDU: Use DDU to completely remove all Intel graphics drivers
  4. Restart normally: Boot back into Windows normally
  5. Install latest driver: Download and install driver version 32.0.101.7028 from: https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
  6. Test streaming: Try Discord streaming after the clean installation
Sometimes driver remnants or conflicting configurations can cause streaming performance issues that persist even after standard driver updates. A clean installation removes all traces of previous drivers and ensures optimal configuration.
Dean R.
AsterCrash
DeancR_Intel
Hi AsterCrash,
Intel has just released a new graphics driver that may resolve the issue you've been experiencing.
Intel® Arc™ & Iris® Xe Graphics - Windows* Version: 32.0.101.7029 Download Link: https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
Please follow these steps:
  1. Test your graphics functionality to see if the issue is resolved
This latest driver includes important updates and improvements that may address the problem you encountered. Many customers have found that updating to the newest driver version resolves similar issues.
After installing the new driver, please let us know:
  • Whether the issue has been resolved
  • If you continue to experience any problems
  • Any changes or improvements you notice
Dean R.
AsterCrash
Hi, the new driver didn't improve, but I disabled the GPU scheduling by hardware and it improved a lot. It's not 100%, but I feel like it can be improved a little. The games aren't crashing when using the insane GPU, but I feel a certain instability when I put it to stream. I even did a clean installation of Discord because I thought of files that pointed to my old RTX 3060, but it didn't work. So far, the improvement came from disabling GPU scheduling via hardware, but I feel like it can be improved because when I record using the Windows Game Bar, it is inaccessible in terms of performance, showing that the Intel Arc B580 has a lot of power, but the problem is between Discord and Intel, as far as I tested.
DeancR_Intel
Hi AsterCrash,
Thank you for testing the latest driver version 32.0.101.7029 and for providing the detailed update on your Discord streaming performance issues.
I'm pleased to hear that disabling hardware GPU scheduling has provided significant improvement to your streaming performance, even though it's not completely resolved yet. Your observation that Windows Game Bar recording works flawlessly while Discord streaming still shows instability is very valuable information - this strongly suggests there's a specific compatibility issue between Discord and Intel Arc B580 rather than a general graphics performance problem.
The fact that you performed a clean Discord installation to eliminate any RTX 3060 configuration remnants shows excellent troubleshooting methodology. Your testing clearly demonstrates that your Intel Arc B580 has the necessary power and capability, but there's an interaction issue specifically with Discord's streaming implementation.
Current Status Summary:
  • Latest driver 32.0.101.7029 tested - issue persists
  • Hardware GPU scheduling disabled - significant improvement achieved
  • Windows Game Bar recording - works perfectly (confirms GPU capability)
  • Discord streaming - still shows some instability
  • Clean Discord installation performed - no improvement
Given the specific nature of this Discord-Intel Arc compatibility issue and your comprehensive testing results, I will be investigating this matter further internally. The evidence you've provided clearly points to a software interaction problem between Discord's streaming engine and Intel Arc graphics that requires specialized analysis.
I will get back to you with an update once I have more information available from this internal investigation.
Thank you for your exceptional patience and thorough testing throughout this process.
Dean R.
DeancR_Intel
Hi AsterCrash,
Thank you for your continued patience and the excellent troubleshooting work you've done with your Intel Arc B580 Discord streaming issues. I truly appreciate the detailed testing you've performed, and I understand how frustrating it must be to experience instability during streaming when you know your graphics card has the capability to perform flawlessly.
Your methodical approach - from testing the previous driver, disabling hardware GPU scheduling, performing a clean Discord installation, and comparing performance between Discord and Windows Game Bar - has been incredibly valuable in helping us understand this issue better.
Intel Arc Graphics Driver Version: 32.0.101.8132 Download Link: https://www.intel.com/content/www/us/en/download/785597/intel-arc-graphics-windows.html
Given the specific nature of your Discord-Intel Arc compatibility issue, I recommend performing a clean installation:
  1. Uninstall your current Intel Arc driver through Windows Settings → Apps
  2. Restart your computer
  3. Install the new driver version 32.0.101.8132
  4. Restart again after installation
  5. Test Discord streaming performance
After installing driver version 32.0.101.8132, please test:
  • Discord streaming performance with hardware GPU scheduling both enabled and disabled
  • Any improvements in streaming stability
  • Whether the issue is completely resolved or shows further improvement
I understand this has been a lengthy process, and I genuinely appreciate your persistence in working through these compatibility challenges. Your Intel Arc B580 clearly has excellent performance capabilities, and we want to ensure you can utilize its full potential for both gaming and streaming.
Please let me know the results after installing the latest driver.
Dean R.
AsterCrash
When using hardware scheduling, it drops a lot and keeps dropping. Regarding instability, it has improved a little, but it can be much more polished.
DeancR_Intel
Hi AsterCrash,
Thank you for testing the latest Intel Arc driver version 32.0.101.8132 and providing feedback on your Discord streaming performance.
I understand that with hardware GPU scheduling enabled, you're still experiencing significant performance drops and instability during streaming. While you've noted some improvement in overall stability, I recognize that the performance is still not at the level it should be for your Intel Arc B580's capabilities.
Your comprehensive testing throughout this process has been invaluable - from the initial CapFrameX data, to testing multiple driver versions, disabling hardware GPU scheduling, clean Discord installations, and now testing the latest driver with both scheduling configurations. The fact that Windows Game Bar recording works perfectly while Discord streaming shows these issues clearly indicates a specific Discord-Intel Arc compatibility problem.
Given the persistent nature of this Discord streaming compatibility issue despite extensive troubleshooting and multiple driver updates, I will be investigating this matter internally. The specific interaction problem between Discord's streaming engine and Intel Arc B580 requires further analysis.
Dean R.
DeancR_Intel
Hi AsterCrash,
Thank you for your continued patience and thorough testing with your Intel Arc B580 Discord streaming performance issues.
Intel has released another graphics driver update that may help resolve the streaming compatibility issues you've been experiencing with Discord.
Intel® Arc™ & Iris® Xe Graphics - Windows Version: 32.0.101.8135* Download Link: https://www.intel.com/content/www/us/en/download/785597/intel-arc-graphics-windows.html
  1. Install the latest driver version 32.0.101.8135
    • Uninstall your current Intel Arc driver through Windows Settings → Apps
    • Restart your computer
    • Install the new driver version 32.0.101.8135
    • Restart again after installation
  1. Test Discord streaming performance with both hardware GPU scheduling enabled and disabled
  2. Provide additional diagnostic information:
This additional information will help us better understand the specific nature of the Discord-Intel Arc compatibility issue and work toward a more targeted solution.
Please let me know the results after installing the latest driver and provide the requested video clip and SSU scan.
Dean R.
AsterCrash
Yes, I tested it with the new driver and I still feel instability. After using Windows Capture to capture without it, it stays the same. The game in question I used was Hellblade 2 to capture gameplay while I was streaming on Discord. Unfortunately, the video file was large and does not fit for sending.
DeancR_Intel
Hi AsterCrash,
Thank you for testing the latest driver version 32.0.101.8135 and providing the updated SSU report. I appreciate your continued patience with this Discord streaming instability issue on your Intel Arc B580.
I understand that you're still experiencing instability when streaming on Discord, even after testing with the new driver. Your comparison using Windows Capture (which works fine) versus Discord streaming (which shows instability) continues to confirm this is a specific Discord-Intel Arc compatibility issue rather than a general system performance problem.
For the large video file demonstrating the streaming performance issues, you can upload it to any third-party file sharing service and provide the link:
Recommended options:
Please upload the Hellblade 2 gameplay video showing the Discord streaming instability and share the download link. This visual evidence will be crucial for our analysis of the specific performance issues you're experiencing.
  • Latest driver 32.0.101.8135 tested - instability persists
  • Windows Capture works perfectly (confirms hardware capability)
  • Discord streaming shows instability (compatibility issue)
  • Hardware GPU scheduling previously provided improvement when disabled
The video demonstration combined with your updated SSU report will help us provide more targeted analysis and potential solutions for this Discord streaming compatibility issue.
Please share the video link when convenient, and I'll continue working toward a resolution.
Dean R.
DeancR_Intel
Hi AsterCrash,
Thank you for getting back to me. I will be checking this further internally and get back to you as soon as possible when the information you need is available.
Dean R.
DeancR_Intel
Hi AsterCrash,
I want to let you know that we are fully aware of this issue and are currently investigating it. Your detailed troubleshooting efforts, including the CapFrameX logs, video evidence, and comprehensive testing across multiple driver versions, have been invaluable in helping us understand the scope of this problem.
Your patience during this investigation process is greatly appreciated, and I'm committed to resolving this Discord streaming compatibility issue.
I'll keep you updated as we make progress on this investigation.
Thank you again for your patience and for providing such thorough documentation of the issue.
Dean R.
