Intel® ARC™ Graphics
3298 Discussions
Ghost of Tsushima driver problem arc b580
HitterAsif
hi
i just bought intel arc b580 few days ago. everything is good except ghost of tsushima.
there are some issue with game texture. please fix this issue.
RobbieR_Intel
Hello HitterAsif,
Thank you for reaching out. I understand that you are encountering artifacts in Ghost of Tsushima.
Please answer the following questions:
  • Does the issue occur only during cutscenes? Or does it also happen during regular gameplay or menus?
  • Have you tried adjusting the graphics settings?
  • What are your game settings? Kindly provide a screenshot
  • Did you verify the game files or reinstall the game?
  • When did the issue start? Was it after a specific driver update or game patch?
  • What game platform are you using?
Please generate an SSU report to help me further analyze important details on your system. To generate the SSU report, please refer to the article: How to get the Intel® System Support Utility Logs on Windows*. Please send us the generated SSU.txt file.
I look forward to your reply!
Robbie R.
RobbieR_Intel
Hello HitterAsif,
Robbie R.
HitterAsif
Yes thank you and when will intel xess 2 release on fortnite, delta force
RobbieR_Intel
Hello HitterAsif,
Thank you for your response. I would like to know if the issue has been resolved or if you need further assistance?
I look forward to your response!
Robbie R.
RobbieR_Intel
Hello HitterAsif,
I would like to know if you would need further assistance with the issue being encountered from the game Ghost of Tsushima.
Additionally, I have sent you a private email.
Robbie R.
RobbieR_Intel
Hello HitterAsif,
Robbie R.
Guardtsuba
Im having exact same problem as you. İf there is any way to fix i would like to know..
-windows 11 with latest update
-using latest graphic drivers
-resize bar is on
-İ tried all in game graphic qualities from Max to lowest but didnt make any difference.
Katinas
Hello.
I have also the same problem. I tryed to reinstall game, lower the graphics, check or new updates. Doesn`t help.  It some one working on this problem or no? before I had NVIDIA GTX 1070 and it worked perfecly with this game, but know don´t, when I install INTEL ARC B580.
