Intel® ARC™ Graphics
3401 Discussions
Graphic card Intel Arc A770 16GB purchased
addelucas123
New Contributor II
Good evening!!
I'm David I come to say that performance improvements are missing because I have seen that by putting ultra RDR2 PC I reach 65 DX12 and Cyberpunk 2077 under FPS in ultra 45 1080p quality should improve stability and performance at least compete RTX 3060 Ti and be almost at the RTX 3070 level, Missing to add control panel Intel Arc colors to increase contrast etc
At least ultra ultra 1440p RDR2 80 to 85 FPS with the peak 90 FPS.
Also at least ultra ultra 1080p RDR2 90 to 95 FPS with the peak 100 FPS.
Both drivers improve performance also special performance for this game and others.
then also other improvements DX11, Vulkan and DX12 45% and 100% performance.
Cheers: David
Labels (2)
Carlos_L_Intel
Hi @addelucas123
Thank you for posting on the Intel® communities and we appreciate the recommendations.  In order to assist you can you please help us with the following information:
  • What driver are you currently using?
If you want us to take a deeper look at your system you can also share:
  • Download and install the Intel System Support Utility (Intel SSU): https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View".  Click on "Next", save the report and attach it to your response.
Carlos L.
addelucas123
New Contributor II
Goodnight
I'm David, I need you to check if everything is fine and the Intel Arc A770 16GB graphics card works fine
Carlos_L_Intel
Hi @addelucas123
Thank you for your post. Based on the report I can see your card seems to be up to date with version .3802 plus you have a very recent BIOS as well. Would you like me to check anything specific or the post above was only a suggestion?
Carlos L.
Carlos_L_Intel
Hello @addelucas123
Carlos L.
addelucas123
New Contributor II
good evening
If I updated the bios yesterday, I already contacted Intel and there is an error in the drivers because when I apply 144Hz change and ultra quality it gives me 1 FPS DX12 and I must put 50Hz because if I put 144Hz it gives me 1 FPS let's go to the developers Intel drivers seen the problem
addelucas123
New Contributor II
BruceTennyson
The Intel Arc A770 16GB has a $349 official MSRP. Now, you can get the GPU from a few online merchants, such Newegg. There are a few unique variants created by Intel's board partners in addition to the Intel Arc A770 16GB Limited Edition, which is Intel's own version of the GPU.
Carlos_L_Intel
Hi @addelucas123
Thank you for your post. Just to confirm would you like to keep this thread open since you already got a response from our team? I appreciate your time.
Carlos L.
addelucas123
New Contributor II
yes of course but fix the problem with drivers, from red dead redemption 2 DX12 1 FPS since when I put 144Hz it gets 50Hz and that is drivers and improve performance more to surpass Intel Arc A770 to the RTX 3060 TI between 5% and 7% please
addelucas123
New Contributor II
good morning
I could fix the implementation of Intel XeSS technology for red dead redemption 2 why rockstar does not guarantee implementation by users and players should kindly contact Intel developer engineers to implement that XeSS RDR2 technology
Carlos_L_Intel
Hello @addelucas123
We appreciate your comments and feedback and it is being documented and routed to the appropriate team. Unfortunately, the team will not be able to provide updates regarding the status of the suggestion/request.
We recommend staying tuned and reviewing the Intel® Newsroom for the latest information about Intel® Products.
Having said that, we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored. Thank you for your interest in Intel® Products.
Carlos L.
Carlos_L_Intel
Hello @addelucas123
 Another recommendation we would like to provide is that for XeSS to be implemented on a specific game, it is better to contact the game developer since XeSS implementation must be done on each individual game.
 We will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored. Thank you for your interest in Intel® Products.
Carlos L.
