Playing on an older build that has previously had nvidia GPUs in it with no issues (1070, 1080ti).
Iron Harvest, which is on DX12, has graphics artifacts with any smoke/steam/fire effects. I've attached a screen grab that shows them, underneath the mech. These show up for any of the aforementioned effects, but the colour can vary. I know other games have had a similar issue.
Gameplay is otherwise unaffected. Running at QHD resolution with everything maxed it runs great. I do hear pretty bad coil whine, unfortunately limiting FPS to 60 only helps a little.
Hello NedDarb,
Thank you for posting in the Intel communities. We are more than glad to help you with the artifacts issue when playing Iron Harvest.
Since you mentioned that your system had a graphics card from Nvidia, we would like to recommend running the Display Driver Uninstaller (DDU) software. This software is a driver removal utility that can help you completely uninstall graphics card drivers and packages from your system, trying to remove all leftovers. For more information, you can check our article "How to Use the Display Driver Uninstaller (DDU) to Uninstall an Intel® Graphics Driver."
In case the issue persists, and to better understand your issue, provide us with the following:
- Does the issue improve if you lower the graphics settings?
- Does the issue persist when rolling back to previous driver versions?
- Provides us with a screenshot of the graphics settings you use.
- What is the game distribution service? ( Blizzard, Epic, Origin, Steam, Xbox, Ubisoft connect)
- Create a report using the following tools:
- Intel
System Support Utility (Intel SSU) - Download the Intel SSU
- Open the application and click on "Scan" to see the system and device information. By default, Intel
SSU will take you to the "Summary View." - Click on the menu where it says: "Summary" to change it to "Detailed View."
- To save your scan: click on "Next"; then "Save."
- Intel® Graphics Command Center:
- Open the Intel Graphics Command Center
- Navigate to the Support tab
- Select System Diagnostic
- Click Generate Report
- Select Save and name the output file.
Jean O.
DDU was ran prior to installing the card, and each update since I've done clean install when the option was available. Shouldn't be anything left behind at this point.
Answers to your questions, in order:
- No, and have tried them all
- No, tested with 4146 and 4091
- See attached
- Steam
- What system details would you like to know that the SSU report pulls?
- Is there another way to download the graphics command centre than the MS store?
Hello NedDarb,
Thanks for the information provided.
About the graphics command center installation process, the only option is to install it through the Microsoft Store*. However, the report is not necessary as the information we needed from the report is available on the Tech Power Up screenshot you shared.
Regarding the system SSU, we are looking to gather system information such as CPU, MOBO model, BIOS version, and Operating System Build. However, sometimes the report will contain further information about the system that will help us investigate your issue, such as a reference for possible system bugchecks. The complete SSU report will help us to better assist you with your issue.
Hello NedDarb,
We hope you are doing fine.
Jean O.
Sorry for the wait, was out of town for work.
The SSU detail report is attached. I'll be updating drivers today and will check Iron Harvest to see if the update changed anything.
Hello NedDarb,
Thanks for your response.
Updating your graphics driver would be ideal since the new driver version just released, Production 31.0.101.4314, and BETA 31.0.101.4335. We will be waiting for your response to confirm the outcome of trying our latest driver.
Jean O.
Tested with both the 4314 and 4335 drivers, no change.
Hello NedDarb,
Let us look into this and we will get back to you and post back soon with more details.
Jean O.
Hi!
Same card, same game, same smoke artifact. And rarely flashing rectangles when moving the camera.
Windows 11, relativelly fresh install, there were no other VGA card before. The game from GOG, native install (not gog galaxy). Driver is up to date.
Sincerely: John
Hello NedDarb and JohnA770,
Thank you for reporting this issue. Our priority is to target the most popular games and apps to focus our efforts on providing a high quality, stable experience for the broadest set of users. We will continue to improve our software performance and compatibility throughout 2023 and beyond. While we can’t accommodate your request at this time, please watch this article on our website for any possible changes to this situation
Jean O.
![](/skins/images/318B71AC6E18CAB8E2CA944B2397E849/responsive_peak/images/icon_anonymous_message.png)
