Intel® ARC™ Graphics
3355 Discussions
HDMI isn't detected in ubuntu 22.04 Intel ultra 7 155H
hau
I bought latest ASUS zenbook-14-oled-ux3405 which using intel Ultra 7 155H.
I installed the Ubuntu 22.04.3 LTS but got the problem that HDMI port does't work .
Note: HDMI is working fine in Window 11.
Does anyone know why and how to fix this ?
below is VGA card info
hwinfo --display
27: PCI 02.0: 0300 VGA compatible controller (VGA)
[Created at pci.386]
Unique ID: _Znp.FdW9VZZ6unA
SysFS ID: /devices/pci0000:00/0000:00:02.0
SysFS BusID: 0000:00:02.0
Hardware Class: graphics card
Device Name: "VGA"
Model: "Intel VGA compatible controller"
Vendor: pci 0x8086 "Intel Corporation"
Device: pci 0x7d55
SubVendor: pci 0x1043 "ASUSTeK Computer Inc."
SubDevice: pci 0x1a63
Revision: 0x08
Memory Range: 0x5010000000-0x5010ffffff (ro,non-prefetchable)
Memory Range: 0x4000000000-0x400fffffff (ro,non-prefetchable)
Memory Range: 0x000c0000-0x000dffff (rw,non-prefetchable,disabled)
Module Alias: "pci:v00008086d00007D55sv00001043sd00001A63bc03sc00i00"
Driver Info #0:
Driver Status: i915 is active
Driver Activation Cmd: "modprobe i915"
Config Status: cfg=new, avail=yes, need=no, active=unknown
Primary display adapter: #27
Senkuchan
Valued Contributor II
I suggest you reach out to ASUS for further assistance. I have checked the specs of your computer and it seems that it only supports Windows 11. The problem may be related to the compatibility of the OS with your computer, as Windows 11 works fine. You can find more information on this link: https://www.asus.com/ph/laptops/for-home/zenbook/asus-zenbook-14-oled-ux3405/techspec/
