Intel® ARC™ Graphics
3300 Discusiones
Intel ARC A750 Low usage and CPU bottleneck problem in PUBG
Kyotor
Principiante
3.662 Vistas
Good afternoon, a few months ago I switched to Intel ARC A750 in RX 580 a few months ago and about the games I play, because I constantly play PUBG BATTLEGROUNDS, I am constantly experiencing problems such as low FPS high Drop and constant bottleneck in AMD RYZEN 5 5600X and I tried the game in DX 11 - DX12 and my operating system I use is Windows 10 IoT Enterprise LTSC version 19044. I use version 5737, I tried win 11 but I did not get good results and I was victimized because I had constant bottleneck problems, I urgently need an optimization on this issue, I also need an optimization on this issue, the driver I use is Intet Graphics Driver 32.0.101.6734 version, I also use bios Version 4631 motherboard PRIME B450M-K II and I want to share with you the screenshot and I only use textures there in the game and I play 1920-1080P and I play the game URGENTLY I WANT OPTIMIZATION NOW
0 kudos
14 Respuestas
JedG_Intel
Moderador
3.559 Vistas
Hello Kyotor,
I'm sorry to hear about the issues that you encountered with Intel Arc A750 while playing PUBG. I perfectly understand how important this is to you. To investigate properly, please share the information below.
1. Is the issue isolated to PUBG?
2. Which digital distribution platform are you using to play the game (Steam, Epic Games, etc.)?
3. What game settings are you using?
4. Did you use DDU prior to installing the latest driver 32.0.101.6734?
5. Is the issue present from the start of using Arc A750 or did the issue happen just recently?
Additionally, to have a better understanding of your system configuration and components please generate System Support Utility (SSU) report. Please follow instructions here and send the report - How to get the Intel® System Support Utility Logs on Windows*
I hope to hear from you soon.
Jed G.
Kyotor
Principiante
3.530 Vistas
1. This problem was not only in PUBG but also in CS2 and FORTNITE. I did not see such a problem in other games.
2. I play PUBG on Steam, I haven't tried Epic Games
3. In PUBG, I use high anti-aliasing, high textures, sharpening and DX11
4. since I bought the video card, I have done a total of about 10 clean installations of the driver with DDU and WINDOWS format, this problem happens with every driver
5. I've had this problem since I switched to ARC A750 and I'm not thinking of using RX580 again because this problem is not fixed, I'm so fed up now that I regret buying it.
In addition, please forward this to the Intel driver team and I don't know if you will make a solution with Krafton, but please make improvements regarding optimization for pubg.
JedG_Intel
Moderador
3.485 Vistas
Hello Kyotor,
Thank you for sharing all this information.
After review, I'd like to inform you that our team is already aware about the issue with Fortnite and CS2. This is now being investigated and worked on. If you want further support on those 2 games, please create a separate thread for each of them so we can assist you properly. We can only cater one issue per thread and this thread will be focused on the issue with PUBG. About it, please get a Capframe data and ensure that you play the game for at least 5 minutes. This will help us compare the values that you are getting on our end.
Please also try to check the following information:
1. Lower or adjust the in-game settings to see if it will make any difference
2. Check for background processes
3. Set the Power Settings to: High Performance
4. Monitor the System Temperatures
Jed G.
Kyotor
Principiante
3.465 Vistas
my months are like this and in the death match 70 60 50 processor usage is happening and there is an abnormal drop problem and the video card dies in crowded places and in some places the processor is using 60 50 again and the video card is also dropping and the bottleneck we know is doing a lot of annoying events and in addition, the screen images I could not make sense but I apologize for this problem that has become too bright.
JedG_Intel
Moderador
3.374 Vistas
Hello Kyotor,
I appreciate your effort in attaching all these screenshots and this would be really helpful with the investigation. Along with these screenshots, please also get the Capframe data, I attached the link on my previous post.
Jed G.
Kyotor
Principiante
3.345 Vistas
Sorry I noticed it late, if there is anything else please tell me.
https://drive.google.com/file/d/1hoPQno6GKbmWHk8iV_ZYyuxO7tJC4cry/view?usp=sharing
JedG_Intel
Moderador
3.313 Vistas
Hello Kyotor,
Thank you for your cooperation. I'll be conducting a thorough investigation and I'll get back to you as soon as possible.
Jed G.
Kyotor
Principiante
3.250 Vistas
Okay, I'm waiting for your response.
Kyotor
Principiante
3.130 Vistas
Are you kidding me people? It's been 3-4 days and you haven't responded. There is still no proper update for the card. These stupid problems have not been fixed for 2-3 years and there is still no fix. I can't understand why you are removing the graphics card. Why are you still removing the graphics card when you haven't done any proper optimization?
I'm sure I'll put this graphics card aside in the future because it's not working properly. Update it to one that works properly and then let's use it.
JedG_Intel
Moderador
3.009 Vistas
Hello Kyotor,
I perfectly understand where you are coming from and I apologize for any inconvenience that this issue has caused. Please know that this issue is being reported to the developers. We'll share another update at the earliest opportunity.
Jed G.
Kyotor
Principiante
2.967 Vistas
I am aware of this but it is not enough. Why doesn't Intel update the A series? It only makes improvements to the B series. I really feel sorry for my money. It is too much.
NormanS_Intel
Moderador
2.344 Vistas
Hello Kyotor,
I wanted to let you know that we have already submitted a bug report regarding this issue. I understand your concerns and value your feedback. While we cannot provide a definitive statement on this matter at the moment, please be assured that we will keep you updated as soon as more information becomes available.
Norman S.
Kyotor
Principiante
1.077 Vistas
Well, how much time has passed for development?
Kyotor
Principiante
1.076 Vistas
If they can't do anything, I'll sell the graphics card and look at the card accordingly, I mean, the guy is smart, the update never comes, the support unit is crap, the graphics card doesn't do thermal paste maintenance, so what is Intel doing then?
Responder
