Intel® ARC™ Graphics
3477 Discussions
Intel ARC A770 temp
Tachman1973
Hi, I'm using Topaz Video enchanced GPU temperature is 76/78 C is it a safe temperature?
LuisGustav_A_Intel
Hello Tachman1973,
Thank you for contacting Intel Technical Support for graphics.
I understand you might experience high-temperature problems with Intel® Arc™ A770 Graphics. We are glad to assist.
In order to investigate further, Please download, run and reply back attaching the .txt file of the tool Intel® System Support and a graphics report (For download go the link https://www.intel.com/content/www/us/en/download/18377/25293/intel-system-support-utility-for-windows.html?product=91600 ).
Thank you for choosing Intel.
Luis A.
Tachman1973
Hello, I am sending the result of this test
Tachman1973
Hi, I do not really understand the questions,
I sent a file with information about the hardware and system test
but no help and answer I did not receive so I do not know how to answer the question asked?
LuisGustav_A_Intel
Hello Tachman1973, thank you for the response.
The system report is useful in terms of reproduction of a certain problem/comparing system behavior with alike software driver/firmware, etc
I am still investigating this to provide you with proper information, as soon as ready I will share post some updates. But in general, if you put the hardware component in a highly intensive task like rendering/transcoding is expected the temperature levels rise.
Luis A.
Tachman1973
I understand all this, I work 25 years with video, everything ok. but I have next to rtx'a 37070 Ti and there is at the level of 60 degrees if the temperature in Intel Arc a770 when redering is say about 78/80 degrees is ok,
there is no problem. The cases are very large and airy, so under this account it is ok. I write only because I have fear whenever I see such temperatures.
Best regards
Tachman1973
Hi, once again I ask if the temp. up to 80 degrees Celsius during GPU calculations is a safe temperature? Best regards
LuisGustav_A_Intel
Hello Tachman1973,
Thank you for your patience.
As soon as possible, let me investigate further to provide accurate information.
Luis A.
LuisGustav_A_Intel
Hello Tachman1973,
I appreciate your patience, in the investigation of the concern. That temperature is considered normal, The threshold for this Intel® Arc Graphics is 90 C.
I will remain attentive if you have a comment about it?
Luis A.
LuisGustav_A_Intel
Hello Tachman1973,
Greetings
Upon checking, looks you don’t have additional concerns and we have provided accurate information about temperature level for your Intel® Arc™ A770 Graphics. This thread will no longer be monitored. If you need further support, please post a new question to provide assistance.
Luis A.
