Intel® ARC™ Graphics
3405 Discussions
Intel ARC GPU not appearing as a second GPU in windows power manager settings
ImpurestClub
Hey! I just picked up an A770 to use AV1 encoding and run it in parallel with my RTX 3080.
Unfortunately, the Intel GPU will not show up in power settings stopping me from assigning programs like OBS to it.
If I disable the NVIDIA GPU then the ARC will show up, but the second I re-enable it the option goes away. I tried installing the most recent beta drive to see if it would solve the issue, but it didn't so I rolled back to 31.0.101.4255. I know ARC is supported because if I disable the NVIDIA GPU the system defaults to ARC without issue. I only want to use the GPU as a secondary workhorse to encode and process video.
I'm on the latest version of Windows 10: 19045.2846.
I've attached Intel SSU logs with the 3080 both enabled and disabled as well as a screenshot showing that both GPUs appear in device manager.
AlHill
try updating your motherboard bios.
ImpurestClub
It's already up to date.
Jean_Intel
Hello ImpurestClub,
Thanks for posting on the Intel Communities. We are more than glad to help you with the issue with your graphics adapter.
To better assist you, please provide us with the following:
  • Is Rezisable Bar Enabled on your motherboard BIOS?
  • Could you try switching the Intel® Arc™ A770 to the first x16 slot on the motherboard to see if it makes any difference?
  • Provide us with a report using Intel® Graphics Command Center:
    • Open the Intel Graphics Command Center
    • Navigate to the Support tab
    • Select System Diagnostic
    • Click Generate Report
    • Select Save and name the output file.
Jean O.
Jean_Intel
Hello ImpurestClub,
We hope you are doing fine.
Jean O.
Jean_Intel
Hello ImpurestClub,
Best regards.
Jean O.
