Intel® ARC™ Graphics
3295 Discussions
Intel ARC a750 vs FNAF games
Waardal
Hello everyone,
I have a problem with FNaF games (FNAF 1, 2 3, 4, Sister Location, Freddy Fazbear Pizzeria Simulator and Ultimate Custom Night, don't know if there are more with this problem). The problem is that on the newest version of drivers (31.0.101.4952) these games don't really work, whenever I lunch them (from Steam, OS: Windows 11) my screen starts going crazy, It's blinking and because of that the games are not really playable. I don't really know what's causing this problem. On the previous versions of the driver it was the same. I think on the latest WHQL version of the driver it worked fine, but i prefer to be up to date with the drivers, even if they're not WHQL. I would be really greatfull for help.
Best Regards
Michael.
Labels (2)
Hugo_Intel
Hello Waardal
Thank you for posting on the Intel® ARC™ Graphics Communities. We will be glad to assist with this flickering screen issue when playing the FNaF games.
Taking into consideration that the issue started after a driver update, I would recommend using Display Driver Uninstaller to uninstall the current driver and reinstall the driver version 31.0.101.4952 to make sure the issue is not caused by a faulty driver installation.
If the issue is only happening specifically in tall of these games it might be related to the game engine and we would need to take a further look at this problem, Have you been able to test any other game and check if the issue happens?
Hugo O.
Waardal
Hello Hugo,
thanks a lot for a reply.
10 minutes ago I've tried DDU and reinstalling drivers and it didn't help out. The problem still occurs. I've also checked some other games in order to find the same bug but didn't find anything, seems like it happens only to the specific FNaF games (for me at least). Hope the problem will be solved soon.
Michael.
Andres_Intel
Hello Waardal,
Thank you for your response and for the information provided, that helped a lot.
We will start with an investigation to provide you with the next steps as soon as possible.
Andres P.
Waardal
I don't want to be mean or anything but it's the second if not the third driver update and the problem still isn't solved. Can I ask how much more time can it take to solve it? It's Christmas time and I really want to play my fav games. Don't want to change my GPU rn.
Michael.
Yukod
I also have the same issue with the FNaF games. It seems that it's about all the games developped with the Clickteam Fusion 2.0/2.5 engine such as "I Wanna Be The Boshy" where the screen flickering problem occurs as well with many more graphical issues.
Yukod.
RonaldM_Intel
Hello everyone,
This issue should be fixed since driver 101.5186 and newer.
To date our latest driver is 101.6130 so please try it out and let me know your feedback.
Ronald M.
