Intel® ARC™ Graphics
3294 Discusiones
Intel Arc A750 Titan Incredible bad performance, help me! 😔
Alexxxxx
Principiante
588 Vistas
I built my first PC a week ago, but I'm getting really bad performance in games. League of Legends sometimes drops to 70 FPS, which makes no sense. CS2 is struggling too, and while Fortnite is a bit more stable, it's still not great. I'm honestly pretty upset about it. I'd really appreciate any help before I consider selling it (not sure if I can even do an Amazon RMA)
For Intel moderators, I've got a JSON file from CapFrameX of a CS2 test if you need it.
PC Specs:
Sparkle Intel Arc A750 Titan OC Edition
Ryzen 5500
Gigabyte B550M K
RAM 16gb DDR4 3200MHz
Windows 11 home
✓Resizable BAR
✓4G
✓Last Drivers
✓Overclocked RAM
✓Already put games on High Performance on windows Graphics Settings.
✓DDU & install last driver - I did it again installing an old driver (it didn't work)
0 kudos
5 Respuestas
ArchieD_Intel
Moderador
502 Vistas
Hi Alexxxxx,
Does the issue occur only during cutscenes? Or does it also happen during regular gameplay or menus?
When did the issue start? Was it after a specific driver update or game patch?
Could you provide a screenshot of your in-game display and graphics settings?
I would also like to obtain 3 CapFrameX log to thoroughly analyze the FPS performance. Kindly ensure that the game would run for a minimum of 3 minutes each.
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility.
Archie D.
Earl_Intel
Moderador
453 Vistas
Hello Alexxxxx,
I wanted to check if you had the chance to review the questions I posted. Please let me know at your earliest convenience so that I can determine the best course of action to resolve this matter.
Earl E.
AbdulJami
Principiante
370 Vistas
Try using older driver 6737- many users report better stability with it on Arc cards. Also double-check power plan and BIOS updates.
Mike_Intel
Moderador
237 Vistas
Hello Alexxxxx,
I am sending another follow up on the information that I requested.
Michael L.
Alexxxxx
Principiante
163 Vistas
Hi Mike,
Sorry, I totally forgot about this post, I've received help from Reddit community, I'm changing my CPU for a better one, I hope it helps me, if it doesn't I will ask for help again
Thank you
Responder
