Intel® ARC™ Graphics
3288 Discussions
Intel Arc A750 low performance with ryzen 5 5600G
ItzAlif
Hi, I bought the intel arc a750 gpu quite a few months ago. From my first start-up, until now, I'm not getting even close to the exact performance as i should be getting according to my system. Let me elaborate a bit.
Here's my system:-
  • Ryzen 5 5600G
  • msi mag b550-m mortar max wifi
  • 2x8GB of 3200mhz ram
  • os: windows 11 23h2
  • antec csk 650w power supply
Now, I have the RE-BAR and xmp on. I saw a benchmark on youtube where the creator had the exact same primary specs as me; yet he was getting much better performance. Here's the link < https://youtu.be/PkaSZwcia_s?si=Z4w-NEGJ3_7PkF2c > In my case, i was getting around 45fps in gta v, quite lower than the one in this yt video. I've tried it with other games as well, and the result was the same, very low performance than expected. I've been having this problem since quite sometime now, a few driver updates came and i updated my driver version each time up until now, but it still didn't work. now, i have the latest driver as of now (version 101.5234).
Jake6
Jake6
someone there at intel?
AlHill
@Jake6   If you bothered to read the thread, you will see that it was closed a year ago.
You should not jump on an old thread.
Start a new thread for your self and provide the problem description and your configuration.
[W10 is this generation's XP]
