Bitte beachten Sie, dass ich Sie nur auf Englisch unterstützen kann. Ich habe ein Web-Übersetzungstool verwendet, um diese Antwort zu übersetzen, daher kann es zu ungenauen Übersetzungen kommen.
Please be informed that I can only support you in English. I have used a web translation tool to translate this response, hence, there may be some inaccurate translation.
Thank you for posting on the Intel
- What was happening before you contact us?
- To get more information from your system, please install, run and attach the logs for the following tool: Intel® System Support Utility for Windows. (Please select the 'Everything' checkbox when you run the tool, so we have all the information we need)
Carlos L.
Hello Frediefeinkost,
Andres P.
We have not heard back from you, so we will close this thread. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Carlos L.
Thank you for your time. We would like to clarify that the card can work with older platforms, it is just that to get the most of it in terms of performance the processor and chipset must support a Resizable BAR.
Carlos L.
Carlos L.
![](/skins/images/7B0AB6865064EAE32B30EC9A4E94B48A/responsive_peak/images/icon_anonymous_message.png)
