Intel® ARC™ Graphics
3300 Discussions
Intel Arc B580. Lag Spikes/Stuttering while shooting in Escape From Tarkov
EShark
I recently upgraded my GPU from 1650 ti to the Intel Arc B580 paired with a ryzen 5 5600G. I had not not encountered any similar issues with my old GPU but when I installed the B580, (Following the instructions given online + deleting any old drivers and using intel support) the game started stuttering/lag spiking while shooting which makes it unplayable. However nothing else triggers any lag spikes, it is just when IM the only one shooting. Is there any fixes for this?
Thanks in advance
Note: I have a TUF Gaming B550-plus motherboard which supports Re-Bar, updated drivers as well
I have also captured data of the lag spikes with CapFrameX and it does show there is clear spikes
RandyT_Intel
Hello EShark,
Thank you for following the guide Need help? Reporting a bug or issue with Arc GPU? - PLEASE READ THIS FIRST! - Intel Community. Lastly, could you please run the Intel® System Support Utility for Windows*and share the logs here. This will provide us with an overall view of your system configuration. Once I have this information, I will coordinate with our internal team, as this issue is currently under investigation.
While there is no specific ETA, I will get back to you as soon as I have any results. Thank you for your patience.
Randy T.
EShark
First, Thanks for the fast reply.
I am attaching the TXT file of my system configuration to this reply. I hope this issue will be resolved quickly so the rest and I who are facing this issue will be able to play the game normally.
Thank you for the troubleshooting efforts
RandyT_Intel
Hello EShark,
Thank you for providing the requested logs. We will work on this internally for investigation, and once I have the results, I will get back to you as soon as possible. Your patience and cooperation are greatly appreciated.
Randy T.
Callenob
I have this issue, tried ti fix it about a month ago but had to go on a work trip. I just opened another ticket with randyT
RandyT_Intel
Hello EShark,
I want to confirm whether you used Display Driver Uninstaller (DDU) to completely remove the previous driver when you upgraded your GPU and updated the drivers. If not, could we try performing a clean installation and then reinstall the latest graphics driver from here: Intel® Arc™ & Iris® Xe Graphics - Windows*
Please follow the instructions in this article and let me know if there are any changes in the game's performance afterward.
How to Use the Display Driver Uninstaller (DDU) to Uninstall an....
Randy T.
Ian-P
Hi Randy,
I just got a B580 myself and wanted to relay that using DDU to remove all drivers from the system and then reinstall the Intel drivers worked for me. I would drop from 100 fps to 17 when shooting, and now everything works as expected.
Ian
RandyT_Intel
Hello EShark,
I wanted to check in to see if you've had a chance to review the information I provided. Please let me know if you still need assistance from us so I can determine the best next steps.
Randy T.
Wave1
Hi Randy,
I'm very interested in the investigation, as I'm experiencing the same issues with extreme lags (from 100fps to 14fps within seconds) while playing EFT.
I recently assembled and set up a new desktop without any previous video cards (dedicated) installed. Consequently, I'm wondering if the DDU tool would be beneficial in this situation.
My PC build consists of an AMD Ryzen 5 7600X3D, an MSI MAG B650 TOMAHAWK mainboard, and an ACR B580. Please find attached my SSU file.
I've done quite extensive research and looked into topics like CPU cache size. My CPU should be sufficient with 96 MB of cache.
Hence, I am very curious and still hopeful that a driver update could fix the issue, as the game is especially unplayable in PvE mode with other players.
I hope this thread will stay open, and I look forward to your solutions.
Best, Björn
RandyT_Intel
Hello @EShark ,
I'm following up to see if you've read my previous response. I want to ensure we can continue investigating this issue. Does the problem occur only when using high settings? If possible, please share a screenshot of your game settings, as we've received reports of an issue with this game when the Texture Quality is set to High.
@Wave1 Please create a separate ticket for this concern so that I can response on your own thread and have it investigated this issue on our end. Thank you.
Randy T.
RandyT_Intel
Hello EShark,
I wanted to check in to see if you've had a chance to review the question I provided. Please let me know if you still need assistance from us so I can determine the best next steps.
Randy T.
RandyT_Intel
Hello EShark,
Since I have not received a response from you, I will now close this ticket. Please note that this thread will no longer be monitored. If you still need assistance, kindly submit a new ticket so we can further assist you. Thank you for your understanding.
Randy T.
