Intel® ARC™ Graphics
3316 ディスカッション
Intel B580 Graphics Card Game Freezing Problem
Anonymous
適用対象外
2,740件の閲覧回数
Hello, I bought a b580 graphics card 10 days
Before installing the card, I cleaned the old graphics driver files with DDU
The game I play has been freezing since I started using the card.
I was previously playing the game with the processor's internal graphics card without any problems.
intel b580 graphics card software is up to date
I am using windows 11 pro version also windows is in its latest state
game download link
https://store.steampowered.com/app/670290/Bilardo_3D__Pool/
Attached is the video of the game freezing moment
You can also find the Intel SSU report attached
Thank you in advance for your help
18 返答(返信)
JeanetteC_Intel
モデレーター
2,688件の閲覧回数
Hello mseksen3,
I will check on this further and will post an update once available.
JeanetteC.
Intel Customer Support
Anonymous
適用対象外
2,639件の閲覧回数
Thank you, if the problem is not solved I will consider returning the graphics card
JeanetteC_Intel
モデレーター
2,608件の閲覧回数
Hello mseksen3,
I understand that you need this issue to be fixed. However, I am still doing further investigation and need help to confirm and share the suggested steps below:
  1. Ensure that ReBAR (Resizable BAR) is enabled in the BIOS.
  2. Update the BIOS to the latest version, 3207, as the current version is 3072 according to the SSU logs.
  3. If the issue persists, share your game settings to attempt replication and share the CapFrameX results so we can check for any recorded stuttering. Link: https://community.intel.com/t5/Intel-ARC-Graphics/Need-help-Reporting-a-bug-or-issue-with-Arc-GPU-PLEASE-READ-THIS/m-p/1494429#M5057
I hope to still get this information from you.
JeanetteC.
Anonymous
適用対象外
2,556件の閲覧回数
Hello
1 - Resizable Bar Bios da has been active since the beginning
2 - Bios version updated to latest version (3208)
3 - I am attaching the CapFrameX results in 3 separate files
JeanetteC_Intel
モデレーター
2,475件の閲覧回数
Hello mseksen3,
Thank you for sharing the information/file I requested. I'll proceed on checking this internally and will post an update once available.
JeanetteC.
Intel Customer Support Techncian
JeanetteC_Intel
モデレーター
2,404件の閲覧回数
Hello mseksen3,
Good day!
I would like to thank you for sharing the CapframeX data, as it helps us investigate the issue further.
I reviewed the CapframeX results and noticed stuttering in the game. Please help provide screenshots of your in-game settings so I can accurately replicate the issue you are experiencing.
I will wait for your reply.
JeanetteC.
Anonymous
適用対象外
2,388件の閲覧回数
I added the in game settings screenshot  there is no other settings section
JeanetteC_Intel
モデレーター
2,369件の閲覧回数
Hello mseksen3,
Good day!
JeanetteC.
Anonymous
適用対象外
2,347件の閲覧回数
Hello, I shared a screenshot of the in game settings in my previous message.
JeanetteC_Intel
モデレーター
2,239件の閲覧回数
Hello mseksen3,
Thank you for sharing/re-sharing the screenshot. I'm still checking on this issue and will post another update once available.
JeanetteC.
JeanetteC_Intel
モデレーター
2,176件の閲覧回数
Hello mseksen3,
Good day.
I tried to replicate the issue you encountered. I've tried to check the freezing and stuttering you mentioned by using the graphics driver 32.0.101.6632.
Kindly check if the issue would persist after using DDU and installing 32.0.101.6632.
JeanetteC.
Anonymous
適用対象外
2,139件の閲覧回数
Hello
I installed version 32.0.101.6632 using DDU, my problem is solved, there is no lag in the game.
Thank you very much for your help.
Anonymous
適用対象外
2,059件の閲覧回数
Hello
The game is freezing again
JeanetteC_Intel
モデレーター
2,023件の閲覧回数
Hello mseksen3
Intel has released a new driver, version 32.0.101.6647 (WHQL Certified). Please proceed clean installation using DDU and let me know how it goes.
JeanetteC.
Anonymous
適用対象外
2,019件の閲覧回数
Hello
When the problem was not solved with the old version, I installed version 32.0.101.6647 using DDU yesterday and the problem still persists.
JeanetteC_Intel
モデレーター
1,924件の閲覧回数
Hello mseksen3,
I'll take note of this for now and will proceed with further investigation. I'll post another update when available.
JeanetteC.
Anonymous
適用対象外
1,852件の閲覧回数
Hello
I returned the card before my return period expired thank you for your help so far.
JeanetteC_Intel
モデレーター
1,718件の閲覧回数
Hello mseksen3,
I acknowledge your decision to return the unit before the return period ends, as you initially indicated. Your thoroughness in providing the necessary information for further investigation is greatly appreciated. We value the troubleshooting steps you've already undertaken to isolate the issue and thank you for your efforts in helping us resolve the matter.
I respect your decision, which is understandable given the current circumstances. If you need further assistance with your Intel product in the future, please submit a new inquiry, as this thread will no longer be monitored.
Sincerely,
JeanetteC.
返信
