Intel® ARC™ Graphics
3331 Обсуждение
Intel B580 old game freezing
Hattaphol
Начинающий
4 170Просмотр.
Hi, I just bought new pc last week. My pc spec is Intel ultra7 265, Asrock livemixer, Corsair 32GB, Kingston 1TB, Thermaltake 750W and Intel B580. I have problem with old game calls Yulgang Online. Most of the time, freezing on character loading screen. I cant do anything, only force close the game and try to login again several time. If the loading character success, I will be able to run around the map but when I start hitting monster. The game is always freezing at this stage. The game was released in 2005. It is MMORPG. Mostly, play multiple character on multiple tabs/windows. It more relies on CPU. It doesnt need high performance GPU. In fact, it even can run with 20-30fps. It just needs to be stable.
here are what I have tested
1. testing window 11 and window 10, problem occurs on both. now back to window11 24H2
2. tried reinstall the game several times, problem still occurs.
3. tried enable/disable resizable bar, problem occurs on both.
4. tried turn on/off game mode, problem occurs on both.
5. disable b580 in device manager and use ultra7 265 onboard GPU. The game run smooth. No freezing at all. However, only 800x600 resolution is available which is not native game resolution. Unable to play with many tabs because all rely on CPU.
6. enable b580 test running game at 800x600 and several other resolutions, problem still occurs.
7. B580 definitely have problem. Test older driver. download old driver as many as possible from intel download center and tested every versions. DDU used
-6913(latest) and 6881 are mostly freezing on character loading screen, always freezing when hitting and some random freezing.
-6877,6876,6874,6795,6793 and 6790 are mostly freezing on character loading screen, no freezing when hitting and still some random freezing.
-6739 and older are mostly freezing on character loading screen, no freezing when hitting, still some random freezing. text, number and some many info are corrupt
Currently, i install 6874 the most playable and newest with WHQL. However, still have problem above which is really annoying.
Anything else I could do? Will we have new working driver?
Метки (2)
0 баллов
24 Ответы
JedG_Intel
Модератор
3 907Просмотр.
Hello Hattaphol,
I sincerely appreciate the effort you’ve taken to explain the issue in such a detailed manner, as well as the troubleshooting steps you have already performed.
To assist you further and address the matter effectively, may I kindly request that you provide the following information:
1. Is the issue isolated to Yulgang online?
2. Was this working fine before?
3. Are there any error messages or crash logs generated?
4. Kindly share the download link to the game.
5. If possible, please provide a short video clip showing the issue.
Additionally, to have a better understanding of your system configuration and components please generate System Support Utility (SSU) report. Please follow instructions here and send the report - How to get the Intel® System Support Utility Logs on Windows*
Best regards
Jed G.
Hattaphol
Начинающий
3 873Просмотр.
Hi,Jed G
Thank for your response
1.So far only this game. Since I just bought this pc a week ago, so i havent tested other programs yet. I will use OBS and Davinci resolve on this pc as well which I already have seen some topic issue about B580 with these 2 programs.
2.No, it never works on this pc. I have played this game on several pc and laptop during 20 years. I never experience this problem before. Even now I do run this game on my old 2014 macbook pro. Even though, it have some lag but it never stuck or freezing.
3.I dont know much about crash logs but there is no error message. it is just freezing.
4. https://www.playpark.com/th-th/yulgang-download/?utm_source=google&utm_medium=ads_vv&utm_campaign=pmax-may2025&gad_source=1&gad_campaignid=20968419539&gbraid=0AAAAADOJaQFRh6z8BeeGs7D21I6lgTts1&gclid=CjwKCAjwyb3DBhBlEiwAqZLe5AZCfwatueoQ6nKdTIS3w6WJV9TYvbkdErLxiKm-YEjq6yijyFzlURoCxW8QAvD_BwE
I am not with my pc right now so I wont be able to do video and SSU logs.
JedG_Intel
Модератор
3 781Просмотр.
Hello Hattaphol,
Thank you for sharing all this information.
May I kindly inquire if you have an estimated timeframe for when you will be able to provide the SSU logs and a short video clip demonstrating the issue? This information will greatly assist us in conducting a thorough investigation and identifying the root cause of the problem.
Best regards
Jed G.
Hattaphol
Начинающий
3 627Просмотр.
Hi Jed G,
short video of freezing problem on driver version 6913 and  6881 attached
SSU attached I'm not sure how it work but i generate it after testing 3 version of driver (6913,6876,6739)  represent 3 scenario problems
which i have explained already.
I cant put all freezing scenario in video because your maximum upload size is 23mb so the video is so short. I will try to record and edit the video. I may upload some more
Thank you
Hattaphol
Начинающий
3 625Просмотр.
here are example of freezing problem on driver version 6790 to 6877
Hattaphol
Начинающий
3 623Просмотр.
here is example of problem on driver version 6739 and older
JedG_Intel
Модератор
3 284Просмотр.
Hello Hattaphol,
Thank you for sharing all this information. I really appreciate all the videos you attached. To further troubleshoot the issue, please try to follow the steps below.
1. Update your BIOS to the latest version 1.13
2. Adjust the graphics settings
3. Check if there are any patches or updates available
4. Enable Resizable BAR
If the same issue is observed, please let me know.
Best regards
Jed G.
Hattaphol
Начинающий
3 139Просмотр.
I have updated bios to 1.13 and done 1-4
same issue with same scenario still occur
JedG_Intel
Модератор
3 005Просмотр.
Hello Hattaphol,
I appreciate your effort on trying the recommendations I shared. Since the same issue persists, kindly share the additional information below for us to replicate this in our test lab if possible.
1. Exact game settings being used:
2. Generate logs that can help us debug the issue, here's a guide - Need help? Reporting a bug or issue with Arc GPU? - PLEASE READ THIS FIRST!
Best regards
Jed G.
Hattaphol
Начинающий
2 983Просмотр.
1. the game is old. There is nothing much on game setting. In fact, I tested it already and it is not related. You better download the game and check it by yourself
2. I follow the guide, ran those commands in command prompt as admin but there is no dump created.
3. I also have another problem video playback graphical glitches
I'm old and I'm not a computer guy. I bought both CPU and GPU from intel. It is 2 weeks already since i bought this pc and it doesnt work like it should be from the first day. I think this is too much already. I am a customer. I didnt pay money to do this work. I think, it is time for intel engineers to put some effort. Just download the game and test it in your lap. I already attached game download link as your request. Furthermore, There is a game call "scions of fate" which is actually the same game but in English. It is available on Steam. You may use it as a guide. I hope to see new driver that fix this problem soon
Thank you so much
JedG_Intel
Модератор
2 672Просмотр.
Hello Hattaphol,
I perfectly understand your situation and I would like to apologize that you encountered this issue. I will check this matter internally and I'll get back to you as soon as possible.
Best regards
Jed G.
JedG_Intel
Модератор
2 497Просмотр.
Hello Hattaphol,
I'm writing to inform you that we were able to replicate the issue in our test lab. I would like to apologize for any inconvenience that this issue has caused.
Rest assured, we are actively investigating the matter and will continue our troubleshooting efforts to identify and resolve the root cause.
Best regards
Jed G.
Hattaphol
Начинающий
2 300Просмотр.
I am still waiting. Could you please share any progress?
Ernesto_C_Intel1
Модератор
1 904Просмотр.
Hi @Hattaphol
Thank you for reaching out. I'm currently working to recreate the issue you've raised.
I'll provide you an update as soon as possible.
Ernesto C.
JedG_Intel
Модератор
1 849Просмотр.
Hi Hattaphol,
Based on our investigation, the game seems to run fine when running the game as an Administrator. Therefore, please try to follow the steps below.
  1. Upgrade their graphics driver to the latest graphics driver version: 32.0.101.6972 (Latest)
  2. Open the game as an Administrator
Jed G.
JedG_Intel
Модератор
1 587Просмотр.
Hi Hattaphol,
I'm checking to see if you were able to try the recommendations I shared. Please let me know if you continue to encounter the same issue so we can investigate further.
Jed G.
Hattaphol
Начинающий
1 559Просмотр.
6987 release today so i test it as well
I run the game as Administrator. They do not work. In fact, admin mode doesnt matter. 6972 and 6987 behave like 6913 and 6881. They are mostly freezing on character loading screen, some random freezing and always freezing when hitting monster ( always mean 100% test it 100 times it freeze 100 times) (100% unable to play)
Please answer these questions
1. What game did you actually test it? Scions of fate or Yulgang? even though they are similar but they are not exactly same. So you can use scions of fate as a guide but anyway you must test on Yulgang
2. Did you really create any character? not just launch the game.
3. Did you move character to hit any monster in game? 6987,6972,6913,6881 always freeze when hitting monster unlike 6877 and older.
JedG_Intel
Модератор
1 380Просмотр.
Hello Hattaphol,
I appreciate that you followed our recommendation and I'm sorry to hear that the issue persists. We'll continue to troubleshoot the issue and we'll also try to share some videos of our replication if possible. I'll get back to you as soon as possible.
Best regards
Jed G.
JedG_Intel
Модератор
1 304Просмотр.
Hello Hattaphol,
I’m following up to share the results of our replication efforts. Kindly refer to the attached video for a visual demonstration.
Additionally, please find below our responses to the questions you previously raised.
1. Without the running the game using administrator, we can't create a character in Yulgang Online (I used the link that you provided) since I'm encountering the same issue.
2. We tried running the game using Administrator and we were able to create a character.
3. Something that was not added on the video is that we were able to explore the starting village and fight frogs on its outskirts.
Since the issue still persist, please be advised that we are currently investigating the possible causes of the issue and we will provide our best effort in addressing the issue since the issue is not isolated on Intel drivers.
Best regards
Jed G.
Hattaphol
Начинающий
1 285Просмотр.
Thank for testing
What is spec of tested pc?
What and How many driver version did you test?
Did you also test with onboard graphic to see differences?
Could you please provide me video of fighting frogs?
Ответить
