Intel® ARC™ Graphics
3292 Discussions
Intel arc gpu need help setting up 3 monitors
Dreadnaught
I recently finished my build and set everything up ( OS,drivers,bios,etc ) but I'm getting an issue with my main middle screen, it is constantly flickering on and off and I honestly don't know what's going on and how to fix it. I can't really don't anything on the main monitor making it useless until it's fixed. I never set up multiple displays ( 3 monitors ) before and I'm really confused. I know it's not the monitors themselves because I was using them a couple weeks ago working fine and all the power/ video cables I'm using a new so I know that's not the problem. I don't have other monitor or cables to test so that's out if questing. My a770 drivers are up to date same as OS, I tried using both windows and intel's display software but its all confusing and the monitor identify numbers are all different.
Can anyone help me set up my monitors in detailed steps and needed basic info for set up ? That would really be appreciated.
  1. What is the graphics driver you are using?
    • 31.0.101.5194
  2. Tell us the name of the game or application and where to obtain it (Steam, Epic, etc.) N/A issue is happening on desktop
    3.
    • Processor make and model. Intel i7-13700k (stock settings)
    • Motherboard make and model. EVGA Classified Z790
    • Amount of memory (RAM). 32GB
    • Operating System version/build number. 23H2 22631.3085
    • Power Supply make and model. Corsair HX1500i
  3. Tell us the steps to reproduce the issue (this is very important!). I can't really explain step by step because of the hardware / monitors I'm using. I pretty much installed the latest arc display driver and the center middle monitor (of the 3) is constantly flickering to a black screen then back to desktop screen.
  4. For graphics corruption (per example artifacts, textures corruption or lighting glitches) please use Intel Arc Control to capture screenshots or a video showing the bug.
Dreadnaught
What is the graphics driver you are using? 31.0.101.5194_101.5252
Tell us the name of the game or application and where to obtain it.
N/A, issue is happening on desktop.
If you do not wish to submit the SSU report then at least provide us with the following information about your system:
Processor make and model. Intel i-7 13700k
Evga z790 classified
32gb
Operating System version/build number. Windows 11 (10.0.22631.3085)
Corsair HX1500i
I don't think I can really tell you the steps to reproduce the issue because of the hardware and monitors I'm using. I simply installed the latest arc gpu driver and my main center monitor is all whacked out flickering on and off.
Dreadnaught
Not sure why my reply to my own post was deleted but I put down the info that was requested like specs/ os version and display driver version. Very rude...
Edit: Added specs/ os and display driver info to main post.
