Intel® ARC™ Graphics
3369 Discussions
Intel graphics software
Himel
I can not find tuning option for my gpu in Intel® Graphics Driver 32.0.101.6458/32.0.101.6257 (WHQL Certified) . im a Arc a770 16 gb user.in every softaware version tuning is missing
Himel
Here I have found a solution..but it is not the solution I need. when everytime I power up or restart my computer and open Intel graphics software the software won't run. then I close the program from Task Manager and again open intel graphics software the software opens without tuning option. Then I close the software and go to task manager services and start the intel graphics service then the software has a tuning option. Why I have to close intel graphics software from task bar for opening the software. and why i have to start the service manually everytime when i have to do tunning? what is the solution?
JeanetteC_Intel
Hi Himel,
Thank you for sharing the information I needed along with the additional details about your replication and findings. Your diligence in supplying detailed information is greatly valued. I will conduct further review and ensure you are updated once it is available.
JeanetteC.
iprigg
Hi JeanetteC,
I did some further checking on the issue, and here are my findings. It seems that the problem regarding the malfunctioning of the tuning beta tab is not related so much with the driver version update but rather with the update of the version of the intel graphics software  per se.
What I did is the following:
1) I completely uninstalled the graphics drivers and software using ddu
2) Then I installed the 6460 driver version package along with the intel graphics software that comes with it
3) Then I performed an update to the 6559 driver only, excluding from the installation the new version of the intel graphics software that is packaged along with the new driver (through pressing the custom button and deselecting the intel graphics software checkbox).
Now I have the newest version of the arc a750 graphics driver along with the older version of the intel graphics software (from the 6460 package) and the beta tuning tab works perfectly, without any problem.
So I assume that you should look to the intel graphics software application code to determine where the problem with the beta tuning resides.
Note however,  that the performance issue on DX9 (20% down) and  DX11 (5-10% down) in passmark's 3d benchmark testing persists in this configuration also. So this should be a driver issue that you should look into.
best regards
iprigg
JeanetteC_Intel
Hello Himel,
Based on our investigation, you may check under Services (services.msc) for the "Intel® Graphics Software Service" and ensure that the "Startup Type" is set to "Automatic" and that the service is running.
Please be advised that we are continuing to investigate this issue and will post an update once available.
JeanetteC.
Himel
the startup type is set to automatic..but still all the issues i have noted are still there
JeanetteC_Intel
Hello Himel.
I've taken note on this and please be advised that we are currently investigating this issue and will post an update once available.
JeanetteC.
Felipe_Intel
Hello all,
Our latest driver 32.0.101.6651 comes with a new version of IGS, 25.8.1206.1 and this issue should be now fixed. Could you please test on your end and confirm?
You can find the driver here
https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
Looking forward for your answer
Ernesto_C_Intel1
Hi @Himel
Since we have not received any response from your end after @Felipe_Intel provided the fix to the issue you've cited, I'll proceed to close this case now.
Feel free to create a thread if you have any questions.
Ernesto C.
