Intel® ARC™ Graphics
Comunicados
3461 Discussões
MW2 Performance issues , newest Driver 4146
Radbod
Novo colaborador I
10.809 Visualizações
Hi there,
with the newest Driver there are some new Probs in MW2.  Performance Dropped 8.8% (!!!) in Avarage AND Low 1st !
Sometimes you ll have to switch between XeSS options and apply, to even get it Working properly in Game. Everytime when an MP Round starts, you ll get <60 fps for e few Minutes and then the FPS Rise to "normal"
Here some numbers of the in Game Benchmark in comparsion :
Driver 4091                    Avarage                   Low 1st
XeSS Ballanced              91                            59
XeSS Performance        94                           60
XeSS Quality                  88                           57
Driver 4146
                                           Avarage               Low 1st
XeSS Ballanced               83                         53                **
                                           93                          58                *
XeSS Performance         91                         61
XeSS Quality                   76                         50               **
                                           88                          58              *
** First Benchmark after starting the Game and *Second Benchmark after changing the Value from any Xess Value back to another and apply .
Plattform Battlenet, newest Game Version
SSU Attached!
12 Respostas
Hugo_Intel
Funcionário
10.757 Visualizações
Hello Radbod
Thank you for posting on the Intel® ARC™ Graphics Communities. I am sorry to hear that you are experiencing a performance issue with the new driver on Call of Duty: Modern Warfare 2. Please let's try the following:
1.-Uninstall the driver using Display Driver Uninstaller, once uninstall reinstall the latest version 30.0.101.4146 and check if the issue persists.
If the issue continues to happen, please share with us the following information:
  • Share a short video showing this issue.
  • Share a screenshot with the in-game graphics settings
  • Is Resizable BAR enabled on your system?
Hugo O.
Hugo_Intel
Funcionário
10.722 Visualizações
Hello Radbod
I hope you are doing fine.
Hugo O.
Radbod
Novo colaborador I
10.684 Visualizações
im allways using DDU and in game Settings werent changed since im Playing MW2 on ARC, so it should make no impact.
I managed to find an issue, that seems to be the cause for the Lag. The CPU usage Jumps all of a sudden to 100% and every time then,
frames drop beneath 60fps!
Normaly its around 49% !
Hugo_Intel
Funcionário
10.668 Visualizações
Hello Radbod
Thank you for the detail that you have shared. Please also share with us the information requested in my previous post so that in case we need to replicate this issue we can do it in the same conditions that you did. We are missing the following:
Hugo O.
Radbod
Novo colaborador I
10.630 Visualizações
reBAR is on
-Settings : see Attached Video
-Problem see YT Link https://youtu.be/YzqamP63IC4
This is Gameplay directly after the First MW2 Start. You see Frames Drop beneath 60fps all the Time and after Changing the XeSS Value ( from Perfomance to Balanced(!!!) ist not Dropping beneath 60 fps and its over all Performance is dramaticly higher!
Hugo_Intel
Funcionário
10.608 Visualizações
Hello Radbod
Thank you for sharing this information with us. We will check this issue internally, and I will post back as soon as I have more information for you.
Hugo O.
Hugo_Intel
Funcionário
10.583 Visualizações
Hello Radbod
Thank you for your patience. Please allow me to tell you that we have tested Call of Duty: Modern Warfare 2 with our latest internal build, playing at 1440p Ultra settings and Xess enabled and there were no performance issues with the game averaging around 100FPS, I am attaching some analytics screenshots for reference.
Please note that this is in our latest internal build so please look forward and keep updating the latest drivers as we make the available since they should resolve these performance issues that you have reported. We appreciate all the Infomation that you have provided throughout this thread.
Hugo O.
Radbod
Novo colaborador I
10.558 Visualizações
What is your Test System i7 i9 13th Gen ? Thats no comparsion.
The Problem was solved with the Beta 4148 but now is back with the WQHL 4255
Its like shown in the Video
Hugo_Intel
Funcionário
10.506 Visualizações
Hello Radbod
Thank you for your feedback. Please note that the testing we did was on our latest internal driver. Allow me to check this with our team and I will post back as soon as I have more information for you.
Hugo O.
intel Customer Support Technician.
Hugo_Intel
Funcionário
10.446 Visualizações
Hello Radbod
We appreciate your patience. We want to let you know that the processor that was used in our previous testing is an Intel® Core™ i9-13900K Processor. To try to equal the processor on your system we did some tests while using an Intel® Core™ i5-12400 Processor and the game in Ultra settings preset with Xess performance mode. We observed consistent results using the last three driver versions available 4091, 4255, 4257. Check the images attached for reference.
Hugo O.
Hugo_Intel
Funcionário
10.379 Visualizações
Hello Radbod
Please let us know if you have further questions or need further assistance.
Hugo O.
Hugo_Intel
Funcionário
10.348 Visualizações
Hello Radbod
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Hugo O.
Responder
