Hello Akrkhan71,
To get a better understanding of the issue and be able to provide an effective recommendation, please provide the missing key information here:
1) Is this a first-time setup and having an out-of-the-box issue?
2) Can you confirm that this is the exact monitor that you have (54.6 Cm Fhd Monitor With LPS Panel Ls22D300Gaw | Samsung India)?
3) How is the monitor connected to the Intel® Arc™ A580 Graphics (thru HDMI or DP)?
4) Are you using direct cable (e.g. HDMI to HDMI or DP to DP) or using a converter/adapter?
Additionally, I highly appreciate you sharing your system configuration so I can fully check and provide you with an accurate fix. This could be possible by downloading the Intel® System Support Utility for Windows* software. When the download is complete, launch SSU.exe.
- Scan: Check the box Everything.
- Click Scan.
- Review: When finished scanning, click Next.
- Click Save. *Attach the SSU log file as you reply.
JeanetteC.
ANSWER: YES
2) Can you confirm that this is the exact monitor that you have (54.6 Cm Fhd Monitor With LPS Panel Ls22D300Gaw /Samsung India )?
ANSWER: YES
ANSWER: HDMI
ANSWER: HDMI TO HDMI
Hello Akrkhan71,
Let us know if you have any questions.
JeanetteC.
ANSWER: YES
ANSWER: YES
2) Can you confirm that this is the exact monitor that you have (54.6 Cm Fhd Monitor With LPS Panel Ls22D300Gaw/Samsung India )?
ANSWER: YES
ANSWER: HDMI
ANSWER: HDMI
Please check the driver settings for the color depth output. "BPC_8" is sufficient for this monitor. The panel can't display more than that anyway. The unavailability of 100 Hz may be due to the driver's calculation that 10-bit @ 100 Hz is not possible because of bandwidth limitations over HDMI 1.4 protocol which this monitor is limited to.
How Do I Set Color Depth or Color Format in the Intel Graphics Command Center?
If you are using Intel Graphics Software, you can find the setting here:
Hello MUC,
Thank you for taking the time to share this information with your fellow community member. I sincerely appreciate your valuable input and contribution to the discussion.
Thanks for sharing this information with the community. Your input is greatly appreciated.
Sincerely,
JeanetteC.
Hello Akrkhan71,
Since I haven't received any response from you recently, I will go ahead and close this thread.
Sincerely,
JeanetteC.
