Hi everyone,
I've been experiencing some serious performance issues while playing Monster Hunter Wilds on my ARC GPU, and I wanted to share my findings and see if others are encountering similar problems.
The Issue:
The last two driver versions, 6266 and 6647, have caused significant drops in performance. Here's a breakdown of my experience:
Driver 6626: With Frame Generation ON, FSR 3, and graphics set to high/medium, I was getting around 35 FPS.
Driver 6647: Performance dropped to around 20 FPS or less, with more stuttering than before. Even after a clean DDU install, it performed worse than 6626.
Older Drivers (6045/6048): Rolling back to these versions drastically improved performance, with stable 50-60 FPS. Gameplay feels much smoother and more consistent.
System Specs:
CPU: Ryzen 5700X3D
RAM: 64GB DDR4 @ 3200 MHz
Storage: 1TB M.2 SSD (where the game is installed)
GPU: Acer Predator ARC A770 16GB
Observations:
I’ve noticed several other reports online from ARC GPU users encountering similar issues with Monster Hunter Wilds. It seems there might be a specific problem with how the recent drivers are optimized for this title.
- « Previous
- 1
- 2
- Next »
Hi everyone. Sorry for the lack of updates. This is a known issue so a bug report has been previously been filed. We're collaborating with CAPCOM as we continue to investigate the issue. I'll post another update here once I have something to share.
Gabriela E.
Hi Samuryan,
This is an update and confirmation: @Herumacil is correct that a fix for the performance issue in this game has been implemented in driver version 32.0.101.6732. I recommend updating to the latest driver (32.0.101.6734) and selecting "Customize Installation," ensuring you check the "Clean Installation" box for a proper installation process.
Dhanniel M.
Hi Samuryan,
I wanted to follow up to see if you've updated your driver and noticed any performance improvements with the latest version (32.0.101.6734).
Dhanniel M.
Hi Samuryan,
As I haven't received a response, I will proceed to close this inquiry. Please remember to update your driver, as the fix for the performance issue has been implemented in driver version 32.0.101.6734. If you require further assistance, feel free to submit a new question, as this thread will no longer be monitored.
Dhanniel M.
- « Previous
- 1
- 2
- Next »
