Intel® ARC™ Graphics
3363 Discussions
NX Cannot render with A770.
宪华
What renderer can render with A770?
DhannielM_Intel
Hi 宪华,
Thank you for posting in the community, I am just quite confuse on the question above. Can you clarify it to me? Are you looking for software to render and compatible with the A770?
Dhanniel M.
宪华
你好
我使用工业设计软件 (NX),不支持 Intel 显卡进行渲染,仅支持 CPU 渲染,所以我想知道是否有任何渲染器或软件可以支持 Intel 显卡并更快地渲染我的设计。
DhannielM_Intel
Hi 宪华,
Based on my research, a renderer application that is compatible with the Arc A770 is AutoCad and Fusion 360. This is based on the system requirement on both application and product specification of Arc A770. If you would like to further inquire about both application, it is highly advisable to contact the developers of the applications. Let me know if you other inquiries I can assist you with.
Dhanniel M.
DhannielM_Intel
Hi 宪华,
I hope you had the opportunity to review the information I posted. At your best time, please let me know it the information I provided satisfy your inquiry
Dhanniel M.
宪华
Thank you very much for the solution, I have successfully used Auto Fusion and Inventor for my work, both of them can work faster with GPU, which has greatly improved my efficiency, of course, I hope to use A770 for more work in the future and hope that you can continue to optimize the drivers of A770 in depth
DhannielM_Intel
Hi 宪华,
Thank you for your feedback, I will take note on this. As such let me know if you have other inquiries that I can assist you or let me know if we can close the thread.
Dhanniel M.
DhannielM_Intel
Hi 宪华,
I wanted to check if you have seen my previous reply, let me know if we can close this thread.
Dhanniel M.
宪华
DhannielM_Intel
Hi 宪华,
Thank you for confirmation on this one as such I will be closing this thread. If you require a further assistance or other inquiry, please submit another thread as this one will no longer be monitored.
Dhanniel M.
qambarali
The Intel Arc A770 GPU supports several renderers depending on your workflow. For gaming and real-time rendering, it's compatible with DirectX 12, Vulkan, and OpenGL. For creative software, you can use renderers like Blender's Cycles, which supports GPU rendering with the A770 via OpenCL or Vulkan. If you're working in 3D software like Autodesk Maya or Cinema 4D, check their GPU renderer support, as updates are making Intel Arc GPUs increasingly compatible. Make sure you have the latest drivers for the best performance!
