Intel® ARC™ Graphics
3330 Discussions
No more XMP after updating A770 driver
blakenet
just found out that because i havent been fast enough to reply, the other thread wont get updates.
(sorry, sometimes, peoples work)
So i recap
Have a problem with black screen on boot sometimes with A770
Last troubleshooting steps where to use ddu, update bios and update graphic card
Bios update went fine
ddu went fine
Graphic card update went fine... until i reboot
once i rebooted the graphic card just stopped initialising at all
had to go on craigslist to buy another graphic card for hundred bucks to make the system boot.
Did a lot of back and forth with bios options to end up with XMP off being the only option changing anything
Something is wrong here... what happened to the video card firmware during the update to make the card no longer working at all with a xmp profile activated (wich works fine with the used graphic card i bougt)
is it possible to revert that firmware update that obiviously happened during the driver update ?
OR is it possible to have a fix that make it possible to activate XMP with that gpu in the computer like it works with the other one ?
Recap from the other post here
https://community.intel.com/t5/Intel-ARC-Graphics/Why-sometimes-the-card-do-not-initiate-display-on-boot/m-p/1528128#M8348
Hugo_Intel
Hello blakenet
I see this is a duplicate topic from your other thread with the title "Why sometimes the card do not initiate display on boot", your original thread has not been closed, it is still open and the issue is under investigation, please continue to post on the original thread to prevent confusion and duplicate efforts. We will be closing this thread, we appreciate your understanding.
Hugo O.
Bandit8623
New Contributor III
have you tried  4885?
i would also include the newest system info with bios updated.   since this is a new thread and youj said you update bios
on this bios?
do you have rebar enabled?  i see you had secure boot disabled on previous post.  so you may have csm enabled.
https://edgeup.asus.com/2021/guide-how-to-enable-resizable-bar-on-your-asus-powered-gaming-pc/
also try to force your pcie to 4.0 vs auto.
Advanced -> System Agent (SA) Configuration -> PCI Express Configuration
Hugo_Intel
Hello blakenet
Hugo O.
