Intel® ARC™ Graphics
3363 Discussions
Problem with w11 and ARC A770
Rayman1
Install the latest version of Windows 11 and the latest card drivers.
Everything seemed to be going well until I started watching videos on YouTube. Where I saw that the videos do not play well, the image stops constantly and jerks.
Does it happen to anyone else? I have the intel arc A770.
Sorry for my English, I use Google Translate.
DhannielM_Intel
Hello Rayman1,
Thank you for posting in the community. Your issue is quite interesting, and I have a few questions to better understand your situation. Please answer the following:
  • Does your screen flicker, or does the video image freeze?
  • Is your current graphics driver version 32.0.101.6460?
  • Are you using Google Chrome? If not, which browser are you using?
  • Does this issue also occur in different browsers?
  • Have you tried disabling hardware acceleration in the browser settings?
  • Have you tried installing an older graphics driver for testing?
Additionally, to better understand your entire system information, please use the System Support Utility (SSU). This will generate a text file that compiles all your system information. You can follow this link for instructions and send the text file here: Help Guide for the Intel® System Support Utility
Dhanniel M.
DhannielM_Intel
Hello Rayman1,
I hope you're doing well. I'm following up to see if you've had a chance to review the questions I posted. Please let me know at your earliest convenience so we can determine the next steps to resolve this matter.
Dhanniel M.
Rayman1
    • The screen does not flicker, the video just freezes as if it were at 1fps
    • No, whit that version I have the problem. I use the ..6458
    • Yes, I use chrome
    • It also happened to me whit edge
    • I didnt´t try this, because it was an update and that´s already started happening.
    • Yes, as I said with the previous one, I don´t have that problem.
DhannielM_Intel
Hello Rayman1,
Could you please specify which older graphics driver version you are referring that is working properly? Additionally, could you try disabling hardware acceleration in your browser settings and see if the issue persists?
Dhanniel M.
Rayman1
The version was 32.0.101.6458
But this morning I skipped an update to version 32.0.101.6557 and with this right now it seems to work fine.
Maybe it's a Windows 11 and 24h2 version thing, since I also restored it and went back to the previous 23h2 version.
And as I mentioned, right now I don't have the problem I mentioned.
Rayman1
The only thing that doesn't work right now is the date on the controller, but this is totally secondary, it's not a problem
The date that comes out is 01/01/0001 I leave a screenshot
DhannielM_Intel
Hello Rayman1,
I'm glad to hear that everything is working fine now and there are no issues with the video playback. I'll check the date on my end. Thank you for bringing this to my attention.
Dhanniel M.
DhannielM_Intel
Hello Rayman1,
Since the issue on this thread has been resolved, and a new issue, such as the minor date error on the IGS, has arisen, I will create a separate internal ticket for further investigation. I will send you an email later regarding the internal case.
As for this thread, I will be closing the inquiry. If you need further assistance in the future, please submit a new question, as this thread will no longer be monitored.
Dhanniel M.
