Intel® ARC™ Graphics
3295 Discussions
Problems with Intel ARC B580 while playing Ghost of Tshushima
Harold9797
Dear developers,
Please give me (or us) a solution to this artifact issues many of us are facing. I've seen multiple posts in support forum but no active solution to this issue.
I am facing this problem since I built my gaming PC with intel arc B580 graphics card. I installed Ghost of Tshushima to play but from the beginning these glitches keep appearing. I did not install any patch. And these things occur during gameplay, in menu and in cutscenes also. I have installed multiple updates of drivers of graphics card, currently running latest1.png2.png3.png5.png and did a clean install each time but yet this issue persists. I have tried reinstalling the game too!
Please help!!
AlphaTop89
I found a solution that worked for me... I use DLSS and set dynamic resolution scaling to 30, and since then, I haven’t had any issues with missing graphics or artifacts. The frame rate is also excellent, especially with frame generation. If it's not working for you, try toggling frame generation on or off, or adjusting settings like V-Sync or anti-aliasing to reduce artifacts. You can also verify the game through Steam to fix any corrupted files or reinstall game patches. Hope it helps tho
Harold9797
Thank you for your support ^_^
Tried each and everything bro. Didn't help...
Aurnab
i have the  same  problem
my gpu : arc b580 m
