Intel® ARC™ Graphics
3420 Discussions
Rainbow six 3 CtD with error code
FurryMLG
OS: Windows NT 6.2 (Build: 9200)
CPU: GenuineIntel PentiumPro-class processor @ 3688 MHz with 2047MB RAM
Video: Intel(R) Arc(TM) A770 Graphics (3)
CreateTexture failed(8007000E).
History: FD3DTexture::Cache <- FD3DRenderInterface::CacheTexture <- FD3DRenderInterface::HandleCombinedMaterial <- FD3DRenderInterface::SetSimpleMaterial <- FD3DRenderInterface::SetMaterial <- ATerrainInfo::Render <- RenderLevel <- FLevelSceneNode::Render <- FCameraSceneNode::Render <- UGameEngine::Draw <- UWindowsViewport::Repaint <- UWindowsClient::Tick <- ClientTick <- UGameEngine::Tick <- UpdateWorld <- MainLoop
Tried reinstalling the driver to no avail
AlHill
Windows NT?
Pentium Pro processor?
Have you read the requirements for ARC?
https://www.intel.com/content/www/us/en/support/articles/000091128/graphics/intel-arc-dedicated-graphics-family.html
[W10 is this generation's XP]
FurryMLG
AlHill
Ok, so you listedd the processor incorrectly.  How about the OS?
Let's get your configuration straight.  So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
FurryMLG
here are the tags
AlHill
Ok, the ssu report says you have a i5-12600K and W11 home..
Whatever tool you are using to get your system info you should delete.
Also, if you go to START, SETTINGS, SYSTEM, ABOUT, you can get your system information.
An Intel support engineer will be responding to your issue.
FurryMLG
I was in system information, where I got that screenshot.
I'm not using any other tools than SSU
FurryMLG
And somehow pentium pro keeps showing up as the cpu on the error code.
AlHill
That would have to be from the game.  Are you running the latest version of the game?
FurryMLG
Yes, I am.  I purchased it through steam
FurryMLG
FurryMLG
I repeated this, and the CtD only seems to affect Operation Cold Dagger.
FurryMLG
No, I do not have a pentium, this is my cpu. Idk why it says that
