Intel® ARC™ Graphics
3370 Discussions
Saturation
Reniel
help i cant find saturation
Earl_Intel
Hello Reniel,
Thank you for posting on the community!
You can adjust the color for your Intel Arc graphics using Intel Graphics Command Center.
Resolution:
Caution: Adjusting color settings changes the color output for everything displayed and should be done only if needed.
Follow the steps below to change your color settings using the Intel® Graphics Command Center:
  1. Open Intel® Graphics Command Center:
  • From the Windows Start Menusearch for Intel Graphics Command CenterClick the Intel Graphics Command Center icon to open the application.
  1. Click Display in the left navigational menu
  2. Select the Color tab.
  3. Ensure you are on a custom profile. The Default color profile is locked; to create a new profile, click the large Custom button.
  4. Adjust the BrightnessColorHue, or Saturation settings as desired.
Click Restore to Original Colors to revert any changes.
Note: Monitors also typically provide a button or menu item for adjusting the color balance. See the monitor manual or contact the display manufacturer for more information.
Reference link: How to Adjust Color Settings Using the Intel® Graphics Command...
Let me know if you have other concerns or questions.
Earl E.
Earl_Intel
Hi Reniel,
I wanted to see whether you had a chance to review the questions I posted. Please let me know as soon as possible so that we can identify the best way to handle this issue.
Earl E.
Earl_Intel
Hi Reniel,
Earl E.
