The card runs fine from a cold boot but if I need to restart the pc through windows I get a no signal message and black screen. I have the correct bios and uninstalled drivers and re applied them to no avail?
Hi jet77,
- Have you checked if the issue persists when using a different graphics card or monitor?
- Are there any error messages or codes displayed when the screen goes black after a restart?
- Have you tried updating the BIOS to the latest version available for your motherboard?
- Can you confirm if the problem occurs only with Windows, or does it happen with other operating systems as well?
- Have you tried performing a clean installation of Windows to see if the problem persists?
- Are there any recent changes or updates to your system that coincided with the onset of this issue?
- Please help generate the SSU logs of your system. Kindly refer to the link below on how to generate the logs:
Archie D.
Hi jet77,
Archie D.
Hi jet77,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Archie D.
