Intel® ARC™ Graphics
3305 Diskussionen
Steelrising doesn't work right
Moomafa
Anfänger
827Aufrufe
I have both an intel b580 and a770 and this game on the b580 performs so terrible compared to the a770 when reflections is on full. i know the a770 was capable to do it though the framerate was wack. its failing and just freezing my PC
i have an intel 12th gen 12700k CPU with resize bar on
an Asrock intel b580 steel legend
g.skill 64gbs of ram running at 4400mt/z
and my game is on steam
Beschriftungen (3)
8 Antworten
Mike_Intel
702Aufrufe
Hello Moomafa,
  1. Let me cheek, are you testing/using the B580 and A770 on the same system or these are two separate systems?
  2. What is your game launcher or where did your download the game?
  3. Can you share some screenshots of the Graphics settings of the game?
  4. What are the troubleshooting steps that you tried so far?
  5. For me to review the hardware and the installed drivers. Please help generate the SSU logs of your system. Kindly refer to the link below on how to generate the logs:
Michael L.
Moomafa
Anfänger
682Aufrufe
1. i am using the same system.
2.i got the game on steam.
3. sure ill add a screenshot.
4.i set the reflections on med and that seems to be fix it and doesn't cause an issue but again when set on high the game and pc freezes.
5. okay i will give you an SSU log
hopefully this is all you need
Mike_Intel
603Aufrufe
Hello Moomafa,
Thank you for the update.
Based in initial checking of the SSU logs, I can see that you are already using the latest Graphics driver, however since you have been changing the Graphics card in your system, please try to install the latest Graphics driver using DDU method. Please refer to the links below for the DDU installation steps and the link of the latest driver:
How to Use the Display Driver Uninstaller (DDU) to Uninstall an...
Intel® Arc™ & Iris® Xe Graphics - Windows*
Michael L.
Moomafa
Anfänger
596Aufrufe
sorry i tried that but it didnt work
Mike_Intel
542Aufrufe
Hello Moomafa,
I will do further research on this matter and post the response on this thread once it is available.
Michael L.
Mike_Intel
507Aufrufe
Hello Moomafa,
I just want to update you that I am about to perform a simulation on this issue.
Before that, let me request for the CapframeX scan for 600 seconds so we can check the game FPS of the game against our tests.
Kindly refer to this link and scroll down to "performance Issue" for the guide on how to use CapframeX.
Need help? Reporting a bug or issue with Arc GPU? - PLEASE READ THIS FIRST! - Intel Community
Michael L.
Moomafa
Anfänger
479Aufrufe
i cannot record because the issue makes my entire pc freeze
Mike_Intel
326Aufrufe
Hello Moomafa,
I will continue to check this again and post the response on this thread once it is available.
Michael L.
Antworten
