Intel® ARC™ Graphics
3403 Discussions
(Suggestion) Find out why Native ASPM is not working.
GTX
Hello. I bought A770 a month ago and it has been consuming a lot of power at idle and I haven't been able to eat during that time.
ASPM L1 was also useless.
I found out the cause by chance. The reason is HAGS.
Most of the ARC users probably used GeForce graphics cards. GeForce users enabled HAGS. However, ARC does not support HAGS. You must disable HAGS.
Here's how to disable HAGS:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\GraphicsDrivers
Change the value of HwSchMode to 1 or delete it.
https://answers.microsoft.com/en-us/windows/forum/all/hardware-accelerated-gpu-scheduling-keeps-asking/4f39e18e-97f2-472e-9147-3ba8e1f6216d
After that ASPM L1 starts working.
Is what I tested reproducible? I think this method is correct. If reproducible, can you modify that registry value when installing the driver?
DhannielM_Intel
Hi GTX,
Thank you for providing this suggestion to us. We attempted to reproduce the situation on our end using a system with an i7-13700K processor, an Arc A770 16GB graphics card, and Arc driver 101.5972. Please see the results of our replication below:
  1. First, we checked the power consumption of the Arc A770 16GB which by default it does not have HwSchMode in the registry, which resulted in a power consumption of 37 watts.
  • Then, we added the HwSchMode to the registry, which increased the power consumption by one watt to 38 watts.
Please let me know if you have other inquiries that I can assist you with. I am looking forward hearing from you
Dhanniel M.
DhannielM_Intel
Hi GTX,
Thank you for posting in the community and for your suggestion. I will note this and discuss it with our engineers. As this requires thorough investigation, I will keep you updated on our progress. Thank you for your input, and we will get back to you as soon as possible.
Dhanniel M.
DhannielM_Intel
Hi GTX,
Dhanniel M.
GTX
DhannielM_Intel
Hi GTX,
Thank you your feedback, for now I will be closing this thread if you need any additional information, please submit a new question as this thread will no longer be monitored.
Dhanniel M.
